Old 09-09-2017, 10:12 PM
Brando0275 Brando0275 is offline
Noob!
Parts interchange thread
Just an idea... I searched several ways but didn't find wha I was after so if I missed it I apologize...
I have had all sorts of Jeeps over the years but just picked up my first FSJ...Actually 2 j10's. I'm missing some things that I can't seem to find. I'm sure there are some common parts that interchange. Headlight buckets for example. I've read that TJ or YJ mounts can be made to work for fsj with a little work. Or some other vehicle seats or seat belts that may work pretty good. It would be pretty handy if someone with experience with these could help put together a list of easily interchanged parts. Just so new fsj guys like me don't wear you out with the same questions over and over. If there's already a sticky somewhere I couldn't find it.
Old 09-10-2017, 06:05 PM
kgocj5 kgocj5 is offline
seats
kinds sounds like you are looking for newer style seats. i bolted corbeau baja rs seats in my 1976 cherokee chief. the corbeau seats bolt right to the stock seat mount holes on the frame of the seat. When the fitament chart say fits cj and yj base it will fit a FSJ too. hope this helps you..
Old 09-10-2017, 06:49 PM
search is broken on forum
use google specify site:ifsa.org and your search terms
you'll get more relevant hits/info/threads
Old 09-10-2017, 07:39 PM
Noob!
That's a start... thanks
Noob!
Thanks
Old 09-17-2017, 11:45 PM
j10jim's Avatar
j10jim j10jim is offline
99 dodge Dakota cab and a half bucket seats bolt right up. I got a set. They are high backs so thats a bonus.
1980 J-10<br />Rusty\'s 4 inch lift<br />2 inch body lift,<br />35 in Xterrains on J20 axles<br />4:30 gears<br />Detroits<br />In-Cab cage thru the dash
Old 09-19-2017, 07:13 PM
Noob!
Thanks
Old 09-21-2017, 05:58 AM
itselliot's Avatar
itselliot itselliot is offline
I did the same...no modification at all, They just bolt right in to the power seat base.
If the PM's are full,...try e mail!
hpschrot@hotmail.com
616 four 03 44 0 five
'78 J-20 401 Q/T not quite stock anymore....Frame off Resto Mod..Super Cab nearing completion. SOMEDAY
"90 GW 360/727/229/3:31s 2" lift (SOLD in 2015)
'78 CJ7 Built from Scratch over a 7 year span.
Old 01-15-2018, 08:07 PM
Jfurda's Avatar
Jfurda Jfurda is offline
Noob!
do you know if the rear corbeau 42" baja bench seat will fit? i have a 79 chief
79 CHerokee Chief
What Kaiser era parts do you want Reproduced??? Dave33rdscb General FSJ Discussion 42 11-29-2015 03:47 PM
Interior Parts Interchange CoveJeepsPA General FSJ Tech 2 05-28-2012 09:02 AM
M715-FSJ parts interchange Jim2928 General FSJ Tech 2 08-18-2002 06:24 AM
1968 Wagoneer parts interchange Murfs 68 General FSJ Tech 2 01-12-2002 07:27 AM
25% off all jeep parts for IFSJA members!!!! billyrb General FSJ Tech 3 09-27-2001 05:03 AM
