  #41
Old 07-26-2017, 10:18 PM
SJTD SJTD is offline
Last picher I see is a single one in Post #35.
Sic friatur crustulum
Old 07-27-2017, 11:53 AM
MJMadness MJMadness is offline
Same, the ones after that seem to be set to private or the links are wrong.
Old 08-06-2017, 08:23 PM
Full Size Jeeper's Avatar
Baby steps, jeep is taking a back seat for a little. Getting my school bus ready for the year, we go back on Thursday. Anyway I ordered a set of floor pans and should be getting them next week. Was able to clean up all my hard brake lines and proportion valve and get the front lines back on. If I have time, I will do the back tomorrow.
1978 Wagoneer
Mods:
Old 08-06-2017, 08:27 PM
Cleaned and reinstalled.
1978 Wagoneer
Mods:
Old 08-06-2017, 08:33 PM
Cleaned up nice. I have a parts Wagon that is pretty much together so I'am using that and pictures I took to help get this thing back together.
1978 Wagoneer
Mods:
Old 08-06-2017, 08:41 PM
Also installed a street light back by the barn so I can work into the evening. Love looking at all the build threads, keeps me motivated.
1978 Wagoneer
Mods:
Old 08-12-2017, 10:05 PM
Floor pans came in.
1978 Wagoneer
Mods:
Old 08-12-2017, 10:42 PM
Don't need the whole pan so I cut it down a bit and screwed it to the floor and marked the floor for cutting.
1978 Wagoneer
Mods:
Old 08-12-2017, 10:43 PM
1978 Wagoneer
Mods:
Old 08-12-2017, 11:02 PM
Was able to get some of the old floor pan out. I used the spot weld cutter from Harbor freight and it worked good, but it was hard to find them all. Also found some more rust where the floor pan transitions into the fire wall, so I will have to figure out that repair. I'am cutting the floor shy of the mark and slowly fitting the new pan.
1978 Wagoneer
Mods:
Old 08-25-2017, 10:30 PM
All of the cage nuts that hold the body to the frame are either striped out or the cage broke loose, so I cut new ones and tapped.
1978 Wagoneer
Mods:
Old 08-25-2017, 10:47 PM
Was able to put one of the new cage nuts back into the broke cage. Two of my childhood friends came over this evening to help me weld. The welding shield quit working so we couldn't finish, but we did make some progress.
1978 Wagoneer
Mods:
Old 08-25-2017, 10:55 PM
I drilled the new floor pans to spot weld to the floor bracing. Most of the large gaps I had my friend Gary weld up and the tight stuff I gave it a try and did okay but it was not pretty. Happy with the way it is turning out.
1978 Wagoneer
Mods:
Old 08-25-2017, 11:00 PM
Where did you get your pans from? How was the fitment?
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 08-25-2017, 11:32 PM
Nor/am auto body parts. I thought they fit well. Looked just like the original ones.
1978 Wagoneer
Mods:
Old 08-27-2017, 03:04 PM
Did a lot of grinding and had to re weld a few spots. Not perfect or pretty, but the rust is gone for now.
1978 Wagoneer
Mods:
Old 08-27-2017, 03:05 PM
primed.
1978 Wagoneer
Mods:
Old 08-27-2017, 03:06 PM
Firewall patch.
1978 Wagoneer
Mods:
Old 08-27-2017, 03:07 PM
Primed.
1978 Wagoneer
Mods:
Old 09-10-2017, 10:17 PM
Cut the drivers side floor and part of the lower firewall out. lots of rust where the lower firewall and floor overlap.
1978 Wagoneer
Mods:
FrankenJeep (Turbo Wagoneer) build thread Ghinmi Street & Performance 230 10-04-2015 09:11 PM
How tall for a daily driver / mild off road Wagoneer lorenmjones General FSJ Discussion 18 09-11-2014 05:57 PM
Build thread - 3x Grand Wagoneer 89/90/91 sportsidedan General FSJ Discussion 22 09-03-2013 12:11 PM
