Old 04-22-2018, 06:33 PM
Geminiroq Geminiroq is offline
Broken EGR CTO...best way to remove?
Hi Team,
I finally have a little time and am working on my cherk.
My EGR CTO was broken and when I went to remove it I found that the nut part was stripped.
I was thinking that if I broke off the plastic part and put a bolt extractor on it that might work...but there is not enough clearance.
What is the best way to remove it?
Any and all advice is appreciated.
Thank you....
Old 04-22-2018, 07:10 PM
I’ve had luck with hammering on next smallest size wrench (usually metric).
The brass is soft, so usually easy to do, and hammering usually makes it easier to break loose.
Best to give a hard sudden smack to break these types loose.
Just pulling/pushing on a wrench frequently rounds them off.
Old 04-22-2018, 09:21 PM
Thanks Tony...I will try that....there is little room to work in so I will have to be creative.
Old 04-24-2018, 01:44 PM
Vice grips too, maybe.
79 Cherokee Chief
Old 04-27-2018, 10:25 PM
ZackN920's Avatar
ZackN920 ZackN920 is offline
You ever get this off?
I'd do like Tony said, but with a deep well socket. Then use the air impact on it.
...not too rusty anymore
Plenty of patina
The others
1926 Dodge Brothers Business Sedan 212 I4-CRANK START
1987 Lincoln Town Car Signature Series-5.0 AOD (WD)
1987 Dodge Dakota LE 3.9, A999, 3.90 gear (DD)
1994 GMC 'Burban 5.7, 4L60E, NP241, 3.42 gear (DD)
2001 Jeep Cherokee 4.0, AW4, NP231, 3.73 (limbo)
Old 05-06-2018, 10:54 AM
Nope....I let it soak with some liquid wrench to help loosen it up.
I tried vice grips....and it broke the head off.
I dont know what to do now??
Any advice is appreciated.
Thank you....
Old 05-06-2018, 01:28 PM
Got enough room to get a punch/drift in there on a corner to hammer it enough to break the grip then spin out with vise-grips??
Old 05-06-2018, 03:29 PM
Did you break it off level with the manifold? Or did you just break off the upper plastic part?
How large is the CTO across the flats? Memory says it's 7/8" ...
If so, this should work http://www.acmetools.com/shop/tools/...rs/irwin-53916
Old 05-06-2018, 03:30 PM
can you take a picture and post what it looks like now? Might help us see what you are working with...
Worst case scenario, I'll be pulling my intake in the coming weeks and would be willing to give it to you, if you want to come get it... (I'm just under an hour from you).
79 Cherokee Chief
Old 05-07-2018, 07:27 AM
It was broken flush....I will try to get a picture.
Old 05-08-2018, 09:35 AM
they make large size e-z outs.
Old 05-08-2018, 07:02 PM
Thanks for all the advice...I will see which one I can get quickly.
The problem is that I need to remove the cherk from the backyard by Sunday....kinda under the gun again.
I will let you know.
Just out of curiosity...can I remove the fitting that the CTO is broken in....or is it part of the manifold?
Old 05-08-2018, 07:04 PM
cto isn’t needed to move it, and yes the rear heater hose fitting unscrews from manifold if that’s the one you’re referring to.
Old 06-12-2018, 03:32 PM
Hey Geminiroq, I tried sending you a PM but your box is full.
Any idea when you want to come pick this intake up? I am hoping to get it out of my garage soon. if you don't want it, I'll probably put a free ad up here on the classifieds with a deadline, then (if no one takes it) I plan to trash it...
79 Cherokee Chief
Old 06-14-2018, 06:15 PM
letank's Avatar
letank letank is offline
If you are talking about the 79, the EGR CTO is up front by the oil filler tube.... if no coolant leak, as said it is not needed to move or drive until next smog check. Plug vacuum hoses as needed
Hard to tell what to do, without a picture
Michel
Old 06-19-2018, 01:10 PM
Any idea if/when you want to grab this manifold? If you don't want it, I'm going to get rid of it soon. Its taking up space on my desk... If you want to swing by Wesdog's garage sale, I can bring it there...
http://www.ifsja.org/forums/vb/showt...26#post1691926
79 Cherokee Chief
Old 06-19-2018, 10:44 PM
sorry for the delay...I cleared out my box and sent you a message.
Replaced EGR and now it runs rough jtrain General FSJ Discussion 23 06-26-2010 11:25 PM
EGR system pics needed! Please help! cavicatz24 General FSJ Tech 0 04-22-2010 08:59 PM
D.I.Y Throttle body injection write up (With pics!!!!) and this is no hoax (Part 2) Wagoneerlover Fuel Injection 7 02-20-2008 12:30 PM
Broken EGR Part -what is it? -pics (air check valve) TimK General FSJ Tech 24 08-06-2005 03:56 PM
EGR testing ? reddog General FSJ Tech 2 02-01-2001 07:24 AM
