Old 01-27-2018, 07:27 PM
Geminiroq Geminiroq is offline
Mystery electrical connector...
Hi Guys,
I have been searching on the web and here on the site and I cannot find the name or part# of the electrical connector in the picture.
I checked the service manual and couldn't find anything....It lays across the manifold...dont know if that is where it should be?
I just need this part, a CTO and an EGR and I should be ready for the SMOG guys...fingers crossed.
Any and all advice is appreciated.
Thanks..
http://cubeupload.com/im/geminiroq/FSJmysterypart7.jpg
Old 01-28-2018, 08:59 AM
that looks like the electrical connector for the distributor, motorcraft. try ford dealer.
Old 01-28-2018, 09:24 AM
MadMax78's Avatar
MadMax78 MadMax78 is offline
Wiley is correct. If it’s currently running you don’t need it any longer. I cut mine off and taped the wires up when I went to fuel injection.
MadMax78
78 Cherokee Chief, Wide Track, 360, TH400, Quadra Trac, SOA, 35" BFG KM2, Edelbrock Carb & Intake
Old 01-28-2018, 12:54 PM
tenoverthenose tenoverthenose is offline
we don't know what he wants.
I don't have a part number, but I did previously look at replacing mine (before I removed the wiring) and remember it being stocked on both Amazon and at O'Reillys.
Old 01-28-2018, 01:05 PM
Excellent....I looked on amazon and tried all configurations, Ford distributor connector, distributor connector, automobile electrical connector...ect....and came back with nothing.
I have an orielly's a mile away....I will be heading there this afternoon
Thank you for all the help!
Old 01-28-2018, 05:38 PM
I always replace the crappy duraspark connectors with weatherpack.
Old 01-28-2018, 09:27 PM
Orielly's was not very helpful so I decided to dig some more online and I think I may have found it!
I believe it is called a
PART# 35-128
ELECTRONIC IGNITION MODULE
FORD CARS & LIGHT TRUCKS 1975 - 1985
TRUCKS 700 SERIES & LARGER 1975 - 1991
F2PZ-12A199-AA, DY683
(MAIN WIRING HARNESS)
http://www.delmarwire.com/repair-har.../ford-pigtails
Anyways....looked it up on RockAuto and found it for about 8 bucks.
Hopefull it is it?
Thanks...
Old 01-29-2018, 08:01 AM
nograin's Avatar
nograin nograin is offline
If you have to look again, the application is "Duraspark II". There's a 3 terminal connector for the distributor to the Duraspark II and a 4 terminal connector for the Duraspark II to the wiring harness.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 01-30-2018, 12:55 PM
I wouldn't replace w/ DS connector if you have to buy a replacement.
Just do this...can snip them out of a GM @ boneyard cost you few bucks.
Can also buy pigtails from parts stores or online.
Old 01-30-2018, 03:57 PM
acct21's Avatar
acct21 acct21 is offline
+1 on what Tony said. If you have to rewire the connectors anyway, don't use 1950s tech. The Weatherpack connectors are superior in every way -- in addition to being rebuildable (just need new pins and seals).
Buy one of these kits and be done with it. For the 3-wire connection at the distributor, just leave one of the ports blank on both sides.
https://www.amazon.com/Delphi-Circuits-Weatherpack-Waterproof-Completed/dp/B078Q4796L/ref=sr_1_20?s=automotive&ie=UTF8&qid=1517349244&sr =1-20&keywords=weatherpack+14
Old 01-31-2018, 05:37 PM
The original Ford plastic connector on the distributor side falls apart pretty readily. Weatherpack is much better.
Old 01-31-2018, 09:33 PM
Thanks to everyone for all the advice....I will look into the weather pack kit in the link.
Stray Electrical Connector GWD6 General FSJ Tech 0 12-19-2014 07:41 PM
ecm electrical connector - where can you purchase the connector rmorit01 Fuel Injection 3 04-27-2013 12:13 PM
Can anyone tell me what this electrical connector is for? Dr. Marneaus General FSJ Tech 12 05-24-2011 08:06 PM
TFI!!! HELP!!!!!!!!(Update!!) Its all about the Jeep General FSJ Tech 29 04-05-2011 03:39 PM
Cant find Electrical connector???? jeeperj20 General FSJ Tech 2 02-24-2009 04:59 PM
