Old 07-15-2014, 03:59 PM
8man's Avatar
8man 8man is offline
Late model GW steering column
OK, I got the early 90 GM column and it is not a direct bolt in to the Jeep. I'll need to cut the firewall mounting bracket off the shaft of the GM column (as it is welded on) and rework the shaft at the Jeep firewall to accept the Jeep split firewall attachment. It does not have the PRNDL on the column, and it is a little longer than the Jeep column, from where it bolts to the dash attachment to the point where it attaches to the steering rod attachment. From the dash attachment point out to the steering wheel it almost identical in length. So it might work, but it won't have the PRNDL on the column.
So does any one know if a late model GW steering column is a direct fit to a early 80's Cherokee? I saw a picture of one and it appeared that they have the tilt and cruise on the column, but do they have the dimmer as well and are they a direct bolt in? If it is a direct bolt in, it does have the PRNDL and would be a lot less work to put it in, if I can find one.
Also, what about the dash gauge cluster? Will a late model GW cluster bolt into the metal dash of a Cherokee?
Thanks
Old 07-16-2014, 07:12 AM
81cherokee laredo's Avatar
81cherokee laredo 81cherokee laredo is offline
Robert,
The early 80's FSJ's (depending on trim level) did have tilt and cruise w/PRND21 on the column. The newer column will be a bolt in, the problem youre going to run into is that the wiper switch is on the dash and the high beam selector is on the floor for the early 80's and on the turn signal stalk for the later G-Wags. For the newer dash cluster the original metal dash is still there, they just cut a lot more out of it to fit the later dash and moved a lot of the controls.
Dan
81 Cherokee Laredo- 360 727 NP219 SOA/SF 35 Coopers 4.56 Gears
83 Cherokee - Katy- long term project
89 Grand Wagoneer- 360 727 NP229 31x10.50's on slot rims
Old 07-16-2014, 04:28 PM
Atla's Avatar
Atla Atla is offline
There was a write-up of a guy installing an XJ column and wheel in, he managed to get the column lights/wipers to work...
http://www.ifsja.org/forums/vb/showthread.php?t=157005
~Atla.
My '83 J-10 Rebuild
Old 07-19-2014, 11:16 AM
CODE 5337's Avatar
CODE 5337 CODE 5337 is offline
I sent you an email with info.
Chris
Steering Column Compatibility Jacksons Hole General FSJ Tech 0 03-13-2011 10:16 AM
Black wire under steering column (Where to?) Wagoneerlover General FSJ Tech 7 01-28-2011 07:52 PM
Steering Column Help lastjeepstanding General FSJ Tech 3 01-08-2011 01:01 AM
Steering column questions JeepBountyHunter General FSJ Tech 0 11-11-2008 11:30 PM
steering column problems ForAmcJeeps General FSJ Tech 0 08-07-2008 07:44 PM
