Old 07-18-2012, 12:17 PM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is offline
Hey watch this...
Steering column wiring diagram???
I know that pretty much every diagram that a person could need has floated through this forum at some time or another, but I am comming up blank with the search option.
Does anyone have the steering column wiring diagram for an 84 GW saved somewhere? If so, I sure could use it!
Old 07-18-2012, 01:06 PM
oljeep.com has wiring diagrams
Old 07-18-2012, 03:54 PM
Dmntxn77's Avatar
Hey watch this...
Thanks... Thats a lot of info! I will dig through there.
Old 07-18-2012, 04:33 PM
j20owner's Avatar
j20owner j20owner is offline
In my opinion, the wiring diagrams on there for 84s are virtually impossible to read. Good luck.
Where is my axle?
79 j20/84 GW GM Hybrid
Old 07-18-2012, 08:16 PM
Dmntxn77's Avatar
Hey watch this...
Yep, they are... Im not sure they will be any help honestly.
I need to know what each wire comming out of the column controls. Trying to figure it out with those diagrams will be like finding a needle in wire loom...
Old 07-18-2012, 08:55 PM
j20owner's Avatar
I'm guessing you mean the turn signal switch, ignition switch, and horn? The 83 might be close enough to figure it out. I need to figure it out on mine, too.
Where is my axle?
Old 07-18-2012, 11:39 PM
Dmntxn77's Avatar
Hey watch this...
Yep... It will be way easier to follow current than it will be to chase it through the diagrams. I was just looking for an easy answer without actually doing it myself.
Old 07-18-2012, 11:46 PM
When I swapped wiring in my '73 I only had to switch a few wires on the column plug (big flat one).
Only stuff inside column is turn signals/hazards/horn maybe cruise don't think mine had it?
The ignition switch/nuetral safety switch, etc. was all exactly the same and just plugged in.
An '83 or '85 wiring diagram will be VERY similar if '84 is hard to read.
XJ steering column swap into a 79. Pics. JeepsAndGuns General FSJ Tech 12 01-21-2018 07:36 AM
Which wiring diagram TJDukit General FSJ Tech 4 03-09-2010 05:52 PM
steering column problems ForAmcJeeps General FSJ Tech 0 08-07-2008 07:44 PM
Loosening the steering column... Dirtball General FSJ Tech 6 03-28-2008 08:16 PM
