Old 05-05-2018, 02:40 PM
MSD is the way to go. I have installed 2 sets myself.
Old 05-06-2018, 06:13 AM
SC/397's Avatar
SC/397 SC/397 is offline
msd gears are (were?) made by the same company that made the OEM,i was told by randy at PAS years ago.
It's possible. They don't look like OEM gears to me but, my eyes are getting old...
Old 05-10-2018, 04:00 PM
Ghinmi's Avatar
Ghinmi Ghinmi is offline
Super Moderator
For what it's worth, I had MSD gears in the first 401 I built way back in 2007 and they worked just fine. Keep up the good work Rick!
Old 05-31-2018, 07:05 PM
SC/397's Avatar
Progress: I round up all of the right size bolts for the water pump and timing cover before I get everything all RTV'd up. I coat both sides of the gasket and install the water pump to the cover first with the bolts just snug - not tightened all the way.
IMG_4623 by Rick Jones, on Flickr
Then I coat the side of the gasket that faces the block first then stick it to the block taking careful care by cleaning out any RTV that is in the oil passages..
IMG_4624 by Rick Jones, on Flickr
Then I coat the back side of the timing cover again cleaning any RTV out of the oil passages.
IMG_4625 by Rick Jones, on Flickr
I torque the timing cover bolts about 2/3 tight and then trim the excess gasket material at the block. The nextday I final torque all of the bolts.
IMG_4626 by Rick Jones, on Flickr
Old 06-06-2018, 04:09 PM
Originally Posted by SC/397
What coating is that on the block? I assume it's a primer...?
79 Cherokee Chief
Old 06-13-2018, 03:40 PM
SC/397's Avatar
Old 06-13-2018, 03:45 PM
SC/397's Avatar
It is Zinc Chromate Primer that I get at NAPA.
Here is a photo of the oil pick-up screen. I use a 1/4-20 x 3/8" long bolt and nut and Loctite them together to use as a button.
IMG_0115 by Rick Jones, on Flickr
I make sure that the oil pick-up screen is located in the right position and test fit the oil pan without a gasket. If it fits without a gasket there are no problems.
IMG_0113 by Rick Jones, on Flickr
Old 06-14-2018, 07:40 AM
babywag babywag is online now
I hope you use good protection equipment when using that!
Zinc chromate is some NASTY stuff, aerosol particles get all over place.
Hope you don’t have a dog or kids that could get exposed to particles.
I still believe that all the crap my dad was exposed to as an airline mechanic killed him courtesy of lung cancer. Zinc chromate is used a lot on planes.
He’s not the only mechanic to retire and then die from cancer.
I know of 2 others he was close friends with.
I also went to school for auto body and got extensive training on hazards of paints/chemicals. Some things are deadly, and gotta protect yourself(properly) from them. I always cringe when I see guys spraying w/o respirator or wearing just a dust mask.
Anyway rant over, awesone engine build as usual.
Old 07-02-2018, 05:43 AM
SC/397's Avatar
Now that I am retired, maybe I can get caught up on engine building.
Block all together, got his fancy brass core plugs in full display, and now ready for the push rods, rocker arms and intake.
IMG_0039 by Rick Jones, on Flickr
Old 07-03-2018, 06:28 PM
SC/397's Avatar
Progress: SCP 1097 BL- I have use quite a few sets of these Scorpion roller rocker arms. These are a direct replacement for the bridged rocker system.
IMG_0043 by Rick Jones, on Flickr
To get the correct lifter pre-load (.040" +-.010" in this case) you can either shim the rocker pedestals or install the correct length push rods. Normally with these rocker arms I use a push rod that is somewhere between 8.200" to 8.300". In this case it fell right in the middle at 8.250".
IMG_0044 by Rick Jones, on Flickr
Priming the oil pump.
IMG_0045 by Rick Jones, on Flickr
I rotate the crank in about 1/4 increments and run the pump. I make sure that all the lifters are pumped up and that all the rocker arms get oil.
IMG_0046 by Rick Jones, on Flickr
Old 07-07-2018, 02:21 PM
cma's Avatar
cma cma is offline
Very nice write up Rick!
Markus!
Picture story:
Old 07-07-2018, 05:11 PM
SC/397's Avatar
Thanks Markus!
We are installing the Air Gap intake on this one. I always use the steel vally pan gasket and the baffle plate under the PCV valve. I cut a chunk of Scotchbrite pad to go between the PCV valve and baffle plate.
IMG_0047 by Rick Jones, on Flickr
IMG_0048 by Rick Jones, on Flickr.
She s just about ready to start!.... Except for the fact that I have to finish a 390 first.
IMG_0053 by Rick Jones, on Flickr
Old 07-07-2018, 05:32 PM
I notice the rubber gasket under the end of the manifold. I used them the last 2 times I did a manifold but I hear lots of people say to trash those and just use a thick bead of sealant. Your thoughts?
79 Cherokee Chief
Old 07-07-2018, 07:05 PM
SC/397's Avatar
I always use the end seals. I use a punch and knurl the block where the seals seat and I cut about half of the tits off. Key things to do are clean the block where the rubber dowels go with a drill bit and use RTV only at the corners. If you get RTV anywhere else the seals will squirt out.
102_2936 by Rick Jones, on Flickr
004 by Rick Jones, on Flickr
Old 07-08-2018, 05:07 AM
to each there own, I always use rtv on the ends, no wrong way to it though
Old 07-14-2018, 11:36 AM
SC/397's Avatar
I really don't like the RTV in place of the gasket. Here is one that someone did and now I have to try to clean it all off with a razor blade. Not a easy thing to do and a hour or so that I don't want to spend.
IMG_0111 by Rick Jones, on Flickr
Old 07-14-2018, 11:56 AM
I understand but I don't like oil leaks either or slipped rubber end seals, what ever works is good, fire that motor up already!
Old 07-14-2018, 01:46 PM
SC/397's Avatar
I have never had a problem with leaks or the seals slipping out. I can't fire the stroker until I get a 390 put together, started, and broke in. I have to multitask with 2 different machinists now to keep things moving forward. Machinist 1 still has a 360 and a 390 to finish for me before I can take 2 more 383 stroker projects to him. Machinist 2 has a 343 ready for me and I need to take him a 360 and 290 to machine up after that. Somewhere in all of that I need to build a couple of 401's and a 427 stroker. I should be caught up in about 10 years I figure...
Old 07-14-2018, 05:01 PM
sounds familiar.
Old 07-15-2018, 03:11 PM
SC/397's Avatar
NEVER buy one of these gasket kits. This one was supplied to me for a 390 build. The very first two gaskets that I took out of the package doesn't fit. The rear main seal is too small by like a 1/4" and the vibration damper seal is small by -.010". There is no press fit and you could shove it out by hand.
IMG_0052 by Rick Jones, on Flickr
The Fel-Pro gaskets are still the best and most complete.
IMG_0116(1) by Rick Jones, on Flickr
AMC 360 Stroker project: Need Advice TWIKEL Street & Performance 11 06-20-2016 06:39 AM
Dodge 360 FI to AMC 360 conversion?? Tinkerjeep Fuel Injection 35 07-24-2014 12:16 PM
'71/'72 360 rebuild questions --stroker kazam General FSJ Tech 12 10-28-2013 04:49 AM
360 or 401 Flashfoto General FSJ Discussion 20 12-24-2012 09:23 AM
258 vs 360 swap Chucks1911 General FSJ Tech 17 02-12-2008 12:47 AM
