Old 10-23-2019, 10:41 AM
Beach_Dude's Avatar
Beach_Dude Beach_Dude is offline
Remaking Factory Harness with OE colors and awg
I've got a few questions about the wire harness for my 77 Cherokee.
On the wiring diagrams, some of the engine bay wires have a name such as "21 BROWN 16 (8 & 6)". From what I gather, the 21 is the circuit number, the color is the wire color, and 16 is what? I assume it's the gauge.
However, many of the wires that are close the the engine are "8 & 6". Does this mean it's a thicker gauge to prevent over heating?
Also, before tearing apart the harness to firewall and fuse box, is there anything that makes it easier? For example, if I unscrew both the fuse panel and the firewall grommet, does it just separate?
Also, if I make this successfully, would anyone be interested in purchasing this? If so, how much?
1977 Jeep Cherokee Chief
360 w/ MC 4350
All stock but ignition and slightly modified suspection
Original paint, garaged/non-op for over 15 years
Old 10-23-2019, 11:27 AM
tgreese tgreese is online now
Yes, gauge.
8 and 6 cylinder engines. Unlike the V8s, 6s have a Delco unitized alternator and maybe other differences, and both schemes are drawn on the same sheet.
I recall there are long screws that attach the bulkhead connector / fuse panel to the firewall. The big screw only separates the connector halves. The fuse panel and body side of the bulkhead connector are one piece.
Old 10-23-2019, 12:17 PM
Full Size Jeeper's Avatar
Not to burst your bubble, but Z&M Jeeps does the engine harness for $250.00 They also have other harnesses for FSJ.
Old 10-23-2019, 02:54 PM
Beach_Dude's Avatar
Well, crap...
Just called and left a message to ask'em a few questions. To voicemail.
Gonna order the wire by tomorrow, let's see if they get back to me... I've been noticing more and more that fsj shops really don't like to get back to ya...
360 w/ MC 4350
Old 10-23-2019, 03:17 PM
itselliot's Avatar
itselliot itselliot is offline
Well, crap...
Be patient...he works part time at the business
If the PM's are full,...try e mail!
hpschrot@hotmail.com
616 four 03 44 0 five
'78 J-20 401 Q/T not quite stock anymore....Frame off Resto Mod..Super Cab nearing completion. SOMEDAY
"90 GW 360/727/229/3:31s 2" lift (SOLD in 2015)
'78 CJ7 Built from Scratch over a 7 year span.
Old 10-23-2019, 06:51 PM
Beach_Dude's Avatar
That guy at z and m was super rad!
Does anyone have a reference, images, or videos on how the harness disconnects from the firewall?
360 w/ MC 4350
Old 10-24-2019, 02:32 PM
I don't understand. Did you read my reply above? Have you put your head under the hood and dash and looked? There's a screw in the middle of the connector on the engine side. remove that and the engine side of the connector unplugs from the connector/fusebox. Look under the dash and there are long (socket head?) screws that hold the fuse box to the firewall. I believe you can see them sticking through on the engine side. Remove those and the connector/fusebox is loose from the firewall, and only held in by the wires. It's all one assembly.
If I remember accurately. I am sure it's not complicated though.
Old 10-24-2019, 04:44 PM
You remember correctly except the engine side is actually two connectors but they are both held by the center screw.
Old 10-29-2019, 03:01 PM
Beach_Dude's Avatar
I'm just gonna redo the bad wire that needs to be done but also tweak a few things...
I can't seem to find the terminal connectors that slip over the threaded studs for the alternator, coolant temp, etc...
What are those female connectors with an angle called?
360 w/ MC 4350
Old 10-29-2019, 04:01 PM
Not sure what they are called, but I found several sources: https://www.wiringdepot.com/store/p/...ail-2-Pcs.aspx
Another: https://www.ebay.com/itm/Ford-Right-...-/272099180726
Try this search - https://www.bing.com/images/search?q=automotive+wiring+pigtail+stud+connectors
Alternator should have a nut and ring connector, not push-on.
Old 10-30-2019, 09:15 AM
Beach_Dude's Avatar
AWESOME! Thank you!
I get the 'fusible link' now! I redid the harness like 15-years ago because of this similar issue. It ends up being that I should have put a fusible link of 14AWG on the charge line.
OMG... It makes sense now!
360 w/ MC 4350
Old 01-01-2020, 06:08 PM
Beach_Dude's Avatar
Decided to make a project out of this harness... It would have only cost a few hundred more to have the ZM setup, but as it is now, original fuse block, all color-coordinated wires, upgraded the entire harness to the MSD with Duraspark and TFI, plus top-quality heat and cut resistant conduit.
The only items left are either being able to remove the male connectors from the rear of the block or solder these in place... Dear god I hope I can pull the plugs out of the block...
TFI connector, everything is not just crimped, but flux used and touched with a 200w solder gun.
Alternator run + Oil Pressure
Here's the Fusible-link that my lack off caused this entire project. Also, the extra 12awg wire for my subwoofer under the passenger side seat, which I haven't finished the connectors for.
And finally, the regulator and connector to the MSD ignition module. Ridiculous, I know... Waterproof. :P
Anyone tried pulling the male pins from the engine bay side of the fuse block?
360 w/ MC 4350
Beach_Dude's Avatar
360 w/ MC 4350
Old 01-01-2020, 07:03 PM
that is a fine job on the harness
that black mesh covering
looks really nice.
Old 01-01-2020, 07:36 PM
lkmarsh's Avatar
lkmarsh lkmarsh is offline
Harness looks great, especially with the woven sleeves.
The male terminals should be Packard 56 series, meaning they unlock
by using a tiny screwdriver or something similar to compress one edge.
This happens from the blade side, not the wire side. In this case, from
the dash side, not the engine bay. Search "Packard 56 connectors" to
see how they work. The larger blades are made the same, Packard 59(?)
Small tool kits are available to make your job easier.
I would not go to the trouble to rewire a glass fuse block. AGC fuses were
always a pain, worse if the sockets rusted up.
Lyle
Seemed like a good idea at the time...
69 1414x Wagoneer 350/TH400 DD & Ski Ride
68 Chevelle wagon 350/BWT50
68 Impala wagon 327/400
73 Cougar droptop 351C/FMX Garage Queen
04 Impala LS - Wife's DD
73 Wagoneer parts donor
Old 01-01-2020, 09:38 PM
Beach_Dude's Avatar
The bulkhead connector is a MESS!!! Got everything separated, took noted, photos, to redo it, but I can't seem to clean the thing up!
Does anyone know a part number for the GM bulkhead connector? Is it still available or orderable?
This is after a good 45 minutes of scrubbing. I think those AMC bastards used tar as an insulator.
360 w/ MC 4350
Old 01-01-2020, 09:50 PM
carb spray works, that crap is awful stuff.
Old 01-01-2020, 10:33 PM
I think the goo was for waterproofing. Haven't started on the engine side of mine yet. Not looking forward to it.
I wonder if the terminals are available. If so I could just cut all the wires and throw the rest in a bucket of solvent until I have to work on it.
Old 01-02-2020, 12:24 PM
Yeah, the brownish goo is dielectric grease, assumedly to block out water and corrosion. Fugly but not a problem. Get some spray cans of contact cleaner, a brush and a lot of rags to clean it. WD-40 might also work well. Whatever you use needs to cut the grease and not harm the plastic - I would not risk using a hot solvent like carb cleaner. You can leave it alone if it does not offend your aesthetic sense too much. Goop it up afterwards with aftermarket dielectric grease, available in a tube. https://www.amazon.com/Permatex-22058-Dielectric-Tune-Up-Grease/dp/B000AL8VD2
These are regular Packard connectors, except for a few larger ones which are just larger versions of the same connector. They should be available somewhere... I can look more later. In the past I've drilled out melted connections and run a wire non-stop through the bulkhead - no one will know but you and me.
Old 01-03-2020, 10:53 PM
lkmarsh's Avatar
https://www.customconnectorkits.com/
buyWiring.com
https://www.repairconnector.com/
Try these for starters, I'm sure there are plenty of other sources.
Lyle
