Old 12-01-2020, 10:56 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
how to install steering column trim
76 j10- truck.
the 2 part "ring" or "collar"
that trims out the steering column below instrument panel.
can't remember removing, not sure how to re install
just noticed the tabs are broken on mine at bottom
need a replacement with tabs,....
so: do you place the two part ring on column, attach 2 screws inside the collar
then slide down and screw onto bottom of dash frame ?
dave in NC
Old 12-01-2020, 03:01 PM
There is not a piece of brittle plastic in my was OTHER THAN THOSE TABS
Wound up using this to repair: https://www.polyvance.com/step3f.php
Smelly smelly stuff, but worked great.
I don't know if yours is the same as my '84, but I believe I screwed the bottom one in first, and then got underneath and screwed the top piece to the bottom.
LMK if you want a photo...
1984 GW
360
Comp 260H
Magnum Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
Old 12-01-2020, 03:08 PM
SOLSAKS's Avatar
heck yes, photo(s) would be nice.
thanx for the reply.
pgsigns2@gmail.com
dave in NC
Old 12-01-2020, 03:31 PM
Here ya go! Was actually able to get a shot inside pretty well...
1984 GW
360
Comp 260H
Performer Intake
Holley SA 670
MSD 8523
NWMP aux tank
1987 GW deceased
Old 12-01-2020, 03:52 PM
SOLSAKS's Avatar
nice.
thanx.
is that nutmeg ?
looks to be in really great s shape.
dave in NC
Old 12-02-2020, 07:26 AM
Yup - nutmeg. Interior is actually in really nice shape though I'll need to get the front seats reupholstered at some point.
Realized you can actually see the tab repair in that last photo - made a mirror image from the opposing side then sprayed it with some color I mixed to match.
1984 GW
360
Comp 260H
Performer Intake
Holley SA 670
MSD 8523
NWMP aux tank
1987 GW deceased
Old 12-02-2020, 07:39 AM
fsj454 fsj454 is offline
Long time member
Color
I have a lot of broken ones . But mite have a usable one what color bottom piece
1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
Old 12-02-2020, 09:05 AM
SOLSAKS's Avatar
THANX FSJ454
I scored one from another member.
look forward to buying the lic plate bracket though.
dave in NC
Old 12-02-2020, 11:44 AM
Bottom part goes on first, then from under the dash you screw the top part on.
Old 12-03-2020, 08:24 AM
SOLSAKS's Avatar
thanx rang.
looked like a puzzle to me.
will a stubby screw driver work on 2nd part ?
or do I need a 90 degree angle screw driver, I have one SOMEWHERE ?
dave
Old 12-03-2020, 11:09 AM
I think I used a long screw driver. I am pretty sure the lower piece goes on with the 2 screws that face the seat, then from underneath you put the top on and screws are angled down and forward toward the pedals...
Steering column instal 8man General FSJ Discussion 3 04-03-2016 07:21 PM
Steering Column Compatibility Jacksons Hole General FSJ Tech 0 03-13-2011 10:16 AM
Black wire under steering column (Where to?) Wagoneerlover General FSJ Tech 7 01-28-2011 07:52 PM
Steering Column Help lastjeepstanding General FSJ Tech 3 01-08-2011 01:01 AM
Steering column problems / steering shaft does not match new column Chrome General FSJ Tech 3 03-11-2006 09:33 AM
