11-29-2020, 09:09 AM
Dana 60
The rear axle on my 87 J20 tends to leak differential fluid out of the wheel hubs. When I took it apart I was surprised to discover there are no inner axle seals around the axle shaft inside the pumpkin like on other axles I've worked on. This allows the differential fluid to travel down the axle shaft housing and dump into the outer wheel hubs. Is this normal? It mixes with the wheel bearing grease and leaks out. I've found some diagrams for the axle and it looks like there never were any seal in the axle tube, the only seal it shows is an wheel bearing seal on the back of the wheel hub.
11-29-2020, 12:48 PM
Uh, those outer axle bearings are live lube from the center. No axle grease. If your seals on the inner part of the hub are bad...a) they are bad or b) the inner edge(seal surface) of the hub is bad.
J20
BP Drivetrain...........
775-537-7918
11-29-2020, 02:09 PM
x2. that is normal for a full-floating axle like most rear dana 60s (no axle seals in the differential). The gear oil also lubricates the wheel bearings. If oil is escaping down the hub then inspect and most likely replace the wheel seals as necessary.
11-29-2020, 05:38 PM
Jeep Doctor
X3. This is what led to that wheel hub video I just made.
12-02-2020, 09:59 AM
Are the gaskets for the axles available anywhere? When I did the brakes on my J20, I bought some Ford D60 gaskets and they are different. The originals are aluminum or some other metal, and I reused them with some RTV. No leaks, but new would be better.
12-02-2020, 10:50 AM
Long time member
Dana 60 rear axle gasket
www.quad4x4.com has them . Part number QU30051
1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
12-03-2020, 07:48 PM
Still puzzles me to see folks run around in circles trying to find unobtanium. Dana 60 has been around fir 60-70 years.
J20
775-537-7918
12-04-2020, 12:39 PM
Long time member
BOB
Same company.
12-05-2020, 05:39 AM
Jeep Doctor
Originally Posted by fsj454
Same company.
Indeed it is!
No wonder the part # was the same...
Thread Tools |
Display Modes |
