03-20-2013, 01:25 AM
80's W/T axle swapp F/R
80's W/T cherokee axle swapp,,360 727 208T Boat/Camper puller weekend mudder with lots of hi-way play with speeds of 65/75 15x10 wheels with 33x12.50 tires what front axle would you pull Dodge Ford Chevy years/make/modle what Rear axle would you use Dana 60,70, or 14Bolt year/make/modle,,,,, front axle must have driver side drop,,
03-20-2013, 07:32 AM
I guess I am a little confused.
What are you trying to accomplish?
Stronger axles?
Spring over?
Tow rig?
03-20-2013, 08:49 PM
Stronger axles?
Spring over?
Tow rig?
Overall Stronger Axles A Must Tow Boat and Camper with 2/3 a month of Mud play
03-21-2013, 05:15 AM
80's J20 axles will keep you SUA, front is not really any stronger, rear is a full floater, you will be 8-lug then and looking for new rims/tires. Rear will need the perches repositioned for the wag/chero width.
03-21-2013, 05:24 AM
I think if it were me , I would stay with the 44, They will keep up with anything the jeep can handle , and the 33's. I would change the gears to 3:73 for the 33's or 4:11 if it is a big camper/boat. With the 4:11 your hwy speed will be less.
03-21-2013, 03:17 PM
Will J10/J20 rear axles clear the Chero/Wag coffin gas tank?
Ben Haines
1980 Wagoneer - GM Perf. Ram Jet 350 crate motor, built 700R4, NP208, 4" lift, 33x10.5 tires.
03-21-2013, 04:53 PM
I'd be more concerned with how much the tires are going to stick out they are significantly wider.
IIRC stock NT is ~58" and J-truck is like ~67"
03-21-2013, 05:47 PM
It appears that he has a W/T and "The Bargin Beater" ran J Truck axles. The rear on a W/T has the axles tucked in and I have thought about putting a J-10 axle , but it doesn't bother me enough for the trouble to do it.
1981 WT Cherokee Chief /360/TF727/208/ Holley 600CFM/ Performer Intake/ Edelbrock headers/ Skip White HEI, switched dizzy gear. Patriot Side Pipes.
Thread Tools |
Display Modes |
