Old 03-13-2013, 02:37 PM
motion vega motion vega is offline
i may regret it but i bought a body lift and new bushings.
been a few years since i installed one. i wasnt even gonna do it but i felt the need for a few minutes and then it was to late to stop myself.
88 grand waggy with almost nothing done to it but a severe beating.
Old 03-13-2013, 08:07 PM
Jeep'rs Creep'rs's Avatar
Jeep'rs Creep'rs Jeep'rs Creep'rs is offline
i just did the same thing. body bushings are on backorder, body lift will be here monday. i guess we should start spraying it down with penetrating oil...
1990 Grand Wagoneer, stock (so far)
"Crate" 360 w/ 7K miles
Old 03-14-2013, 07:25 AM
serehill serehill is offline
Gone,Never Forgotten.
yep
You can't have too much PB balster & you can't start spraying th eboltds too early. It's tedious but not that hard minor adjustments are require but I didn't have ave great issues. I did mine to ahieve lift & keep a low center of Gravity. Well more than total lift. I know it's not everyones cup of tea but I like it better than total lift. one of th ebest results/ side effect was more engine access. Good luck guys It's teedious & wou'll be happe you bough tnew bushing. I used an electric impact on mine to assist with losening th ebolts with great results. pusshing as hard as you can with a wrench is nt good, the impact havvers the bolts loose. It worked on mine. Take you time work the bolts. Replacing the nut plates are not fun.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 03-14-2013, 07:37 AM
I have found with our captive nuts for the body mounts that in addition to very frequent spraying with PB that it helps to tighten them just a little.
tighten...loosen...tighten...loosen
Just enough to break the rust bond and get the penetrating oil soaked into all the threads.
Old 03-14-2013, 09:08 AM
No doubt
Tad's is the
Best process.
I did this with my impact forward reverese forward reverse.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 03-14-2013, 11:07 AM
fortunatly i have a compressor here and at the barn, granted the barns 80 gallon ingersoll will me more helpfull then the 70s 20 gallon belt drive here.i man put this off till it warms up and use the neighbors post lift, since i only have a scissors lift for now.
Old 03-14-2013, 11:28 AM
Yep
I use my electric impact because it is not as strong as my pneumatic one either could work I suppose. I just want the impacrt function not the highest power for this. I suppose there is no wrong way on this.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 03-14-2013, 12:44 PM
Husker77's Avatar
Husker77 Husker77 is offline
Will one of you guys make a thread and document the installation, I would really like to see how it goes.
Old 03-14-2013, 06:21 PM
that is my intention everytime, but i usually get so engrossed that i forget to keep taking pictures
Old 03-14-2013, 07:28 PM
Mr. Goatman's Avatar
Mr. Goatman Mr. Goatman is offline
I've had a kit here for a year but I know I have some loose nuts and just don't want to cut the holes. It would be great to see some picts from you to inspire me.
Remember; When it comes to tools and toys forgiveness is ALWAYS easier than permission!
Old 03-16-2013, 10:52 AM
ill do some pics then i guess.
