Old 09-12-2016, 02:32 PM
Fascination Fascination is offline
Noob!
Cruise control
Help
My 88 GW cruise was working just fine. Then....nothing.
I've purchased a complete replacement on e-bay but everything seems to check out. Column function as all work. Cruise control module has peer to the various functions including servo. No blown fuses. What gives?
Only thing not replaced is the column controls but they indicate good. My cruise control indicator on the dash was working but when the cruise quit so did the light. Any chance that could cause my problem. I hate to just give up.
Thank you all.
Old 09-13-2016, 12:10 PM
Check the function and fuses for your brake light switch.
-Jonny B.
D20 - Twin Stick'd
F D44 - 4.10, Eaton E-Locker
R D44 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 09-13-2016, 12:39 PM
mdcptman's Avatar
mdcptman mdcptman is offline
Jeep Therapist
If your brake light bulb is out, cruise wont work.
88 Grand Wagoneer
360/727/NP208/dana 3.31s
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Quote From Friend's Mom:
Old 09-13-2016, 01:30 PM
2ToneBluJ10's Avatar
2ToneBluJ10 2ToneBluJ10 is offline
Check for vacuum to the servo.
Dave
The few. The proud. The browless.
Somewhere between prissy and pristene
Old 09-13-2016, 02:24 PM
acct21's Avatar
acct21 acct21 is offline
Check the tiny, 4 amp glass inline fuse -- hidden under the dash on the red wire going from the column to the brake pedal/brake light switch (wire may connect to/become a pink wire before the brake switch.
Edited to correct earlier mistake -- I said 'column to cruise module.' There are three wires -- and two go to the module -- but this one goes to the brake pedal switch. Also clarified wire colors.
Old 09-13-2016, 03:29 PM
Originally Posted by acct21
Check the tiny, 4 amp glass inline fuse -- hidden under the dash on the pink wire going from the column to the cruise module.
x2 Both my GW's had blown fuses...and they are hidden. NOT in fuse panel for some dumb reason.
Both worked fine after replacing this fuse.
Old 09-13-2016, 04:28 PM
asudchiman's Avatar
asudchiman asudchiman is offline
This is great to know. Wish I had seen then before putting the driver seat back in.
Anyone have a photo?
1985 Grand Wagoneer - [Blue]
1990 Grand Wagoneer - [White]
1991 Grand Wagoneer - Vin#...001 [White]
1991 Grand Wagoneer [Hunter Green]
4rd: 2005 Jeep Wrangler LJ (Sold)
3rd: 1987 Grand Wagoneer (Sold)
2nd: 2005 Grand Cherokee Limited 4x4 Hemi (Sold)
1st: 1993 Wrangler Sahara (Sold)
Blogs:
Primary:My Jeep and Me
Old 09-13-2016, 08:21 PM
acct21's Avatar
LOL. I had my seat fully back, as reclined as it goes, and was lying upside-down, on my back -- reaching over my head and under the dash. Had to open (and re-close) the inline fuse holder with one hand. I don't know if you could take a picture of the dang thing -- unless you pulled the entire cluster and dash.
It looks just like this one -- push-in-and-twist to open it up.
Old 09-14-2016, 06:05 AM
Originally Posted by Fascination
Help
Thank you all.
We have a cruise control indicator light?
Ours works intermittently and when it does work it pumps the throttle like mad. Been meaning to look into it.
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
1989 Jeep Grand Wagoneer 360
Old 09-14-2016, 11:31 AM
acct21's Avatar
I'd bet that is a vacuum leak between the vacuum ball and your servo.
Old 09-15-2016, 07:24 AM
asudchiman's Avatar
Thanks. I was in the same position but with the seat out. Funny think is, for as many wires I traced I never saw an inline fuse . Guess I get to go on a hunt for it. My cruise is not working, and I am hoping it is something simple like a fuse.
Thanks
Blogs:
Old 09-15-2016, 09:28 AM
acct21's Avatar
Trace a pink wire coming from the brake pedal switch (there may be two, but one will be headed toward the fuse block; you want the other one). It may go through a connector, and may turn into a red wire (in '87 it says 'red with white tracer'). It should be headed for the column loom, but in there is a small inline fuse holder. That 4A fuse is likely toast.
Old 04-20-2017, 11:27 AM
Gibber's Avatar
Gibber Gibber is offline
'89 GW
360
TF727
Dana 44's (2.73)
Baltic Blue/Sand Interior
"Passing everything but Gas Stations"
Old 04-20-2017, 06:36 PM
acct21's Avatar
I suppose that's it; I've only ever felt it -- I've never seen it!
Old 04-23-2017, 09:01 AM
asudchiman's Avatar
Neal, did that fix it?
I just saw your PM today. I've taken some time off from working on the Jeep. Fortunately, I am back at it this weekend. I never found the inline fuse on mine.
Hopefully I will gind it the next time I am under there (which may be today). I need to put in new flashers.
Blogs:
Old 04-23-2017, 11:11 PM
Darwin1876 Darwin1876 is offline
I have an 88 and an 89 never seen a cruise control light. Can someone post a picture of this light?
78 J10
88 Grand Wagoneer
89 Grand Wagoneer
72 J4000
64 J200 (parts truck)
Old 04-24-2017, 07:13 AM
asudchiman's Avatar
not aware of a light? I believe you should be looking for the "hard to find" inline fuse.
Blogs:
Old 04-24-2017, 06:44 PM
acct21's Avatar
Only indication your cruise control works is that you take your foot off the gas and it holds speed...
Old 04-25-2017, 09:23 AM
Gibber's Avatar
That did NOT fix it.
It used to work (like two months ago)....but I'm at a loss now.
'89 GW
360
TF727
Dana 44's (2.73)
Old 04-26-2017, 07:42 PM
asudchiman's Avatar
Maybe I will wait a while before tackling this one.
I am installing Serehill's headlight kit with Fog Light mod.
Then adding HID lighting from amazon.
Have the lights done, still working on fog lights. The HID makes a BIG difference! Also, found a nice used Marchal fog light (thanks to Dave) and a NOS Marchal fog light with an amber lens. I have a good lens, but my housing has plenty of pitting in the chrome. It arrived today, so this weekend I should be able to finish it up and get the brand new grill put back on.
Blogs:
Cruise Control Red20 General FSJ Tech 5 07-30-2011 07:39 AM
Cruise control won't accelerate or decelerate, but works otherwise iroc86 General FSJ Tech 6 07-02-2010 09:38 AM
Cruise Control Adjustment JohnIL General FSJ Tech 1 02-13-2008 11:56 AM
Cruise Control vent box etjeep Off-Road FSJ Tech 0 12-04-2006 12:37 PM
Cruise control (or throttle) sticking?! yipcanjo General FSJ Tech 4 03-31-2005 02:20 AM
