Old 03-10-2009, 01:39 PM
BlacksheepGW's Avatar
BlacksheepGW BlacksheepGW is offline
Newbie (kinda) Hello.
I didnt' see a newbie section to post to, so I'll post here until told otherwise.
Just got a 1984 Jeep Grand Wagoneer. I plan to run 33's with it. I have 35s, but I doubt I can find a lift big enough, or some good fenders to keep Johnny law off me.
I use to have a Jeep Wrangler TJ, and a Jeep Baby Cherokee XJ, and have wheeled for few years now. THis is basically my first FSJ, besides a project involving a Willys.
Yes, I did remember to get pics.
Old 03-10-2009, 01:57 PM
draglink's Avatar
draglink draglink is offline
Blacksheep looks great!! As you can see Im partial to white Wagoneers! I have little over 6" front, 6" rear running 33s. This summer I plan on going 35" with some trimming. Keep the pics coming!!
'86 GW 6" Rustys, 1 1/2" BJs shackles, 33 BFGs
Old 03-10-2009, 01:59 PM
Chevelleguy's Avatar
Welcome. A 6" lift from BJ's Offroad will get you enough clearance for the 33's. If you trim 2" off your fenders you can run 35's. If they are very wide (14.5") on 10 or 12" rims, you could go with the Bushwacker flares for the 4 door XJ's. They fit with some slight modifications.
Old 03-10-2009, 02:11 PM
Ostego's Avatar
Ostego Ostego is offline
Great looking Wagoneer's.
Can't wait until I can get a lift for my J20!
Current:
1974 J20 Pioneer: 6.6L, V8 401, Holley Street Avenger 4 bbl carb.
Old 03-10-2009, 02:37 PM
Dirtball's Avatar
Dirtball Dirtball is offline
Welcome from Alabama... take a look at my pics for 6 inch lift and 34s... with no rubbing...
Paul
1979 Cherokee N/T
360/TH400/Qtrac/D44s/rear Lock-right
6 inch Hell Creek all spring lift
34x10.50 Super Swamper LTBs
http://i54.photobucket.com/albums/g1...t/100_1394.jpg
http://i54.photobucket.com/albums/g1...t/100_1390.jpg
http://i54.photobucket.com/albums/g1...100_1387-2.jpg
Old 03-10-2009, 07:59 PM
What Tcase are you using? I'm still not too sure on the D44 vac disconnect and the NP229
Old 03-10-2009, 08:14 PM
Murphy's Avatar
Murphy Murphy is offline
Welcome BlackSheep. You will love that rig lifted.
DragLink, your rig is coming along. That 6" looks just right. A body lift could probably get 35s under it w/o trimming the fenders if you want to go that route.
If he did have 33"x14.5" or 15.5" wide tires, would the tires still stuff up in the fenders without trimming or flares or would he need more lift for 33's to keep the fenders off of 'em?
Not trying to hijack, the OP may find it helpful also. I ask because I would really like to get some 33x15.50 M/T Baja Claws but I don't want to trim the fenders and Bushwackers are pretty expensive. I'm guessing 8-9" of total lift?
Old 03-10-2009, 10:36 PM
Sian09's Avatar
Sian09 Sian09 is offline
Welcome and nice GW!
'78 J10 Stock for now. 360, 44's F&R, T18, D20, TFI, 5 Slots, 31" ATs, Copper like color.
Old 03-11-2009, 06:46 AM
Mex in the city's Avatar
Mex in the city Mex in the city is offline
Wlecome and nice Waggy. I run 35" and 6" BJ's. It rubbed a lot in the back and it was not that bad in the front. If you plan to drive it on road probably you won't need to trim in the front, but if you plan to wheel it you will have to. I had to trim about 1.5 - 2.0 in front and rear.
83 Wagoneer. Front: 35 spline D60, Coil spring conversion, E-Locker. Rear: Sterling 10.5, Shackle flip, Detroit. Gear ratio 5.38:1. 39.5 Interco Irok's, HEI, hydroboost, hydroassist, bob job, sliders, roll cage, 12K winch. Runs on propane!!!
87 GW, 3", 4.10, 32" BFG AT, K8600, 2131, 1406, HEI, hydroboost.
71 Datsun 240Z turbo.
Old 03-11-2009, 07:30 AM
WELCOME! Good Luck on your new project!
Old 03-11-2009, 07:34 AM
draglink's Avatar
Blacksheep my Wagoneer has the NP228 Tcase...virtually the same as the NP229. They only used the 228 in '86. As far as the vac disconeect on the front 44 Im not at all familiar with it, I think they came on '84 and '85s? Do you have any more pics? If so bring 'em on!
WaveHunter-Thanks, hope yours is coming along well!!
Old 03-11-2009, 07:42 AM
Welcome from the SW....
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 03-11-2009, 09:11 AM
badaboom's Avatar
badaboom badaboom is offline
WELCOME
Welcome to the Rockn World of the IFSJA
Good luck with your projects
1981 Jeep J10 Laredo, 401-V8, 625 Carter, Lunati 262/268, Edelbrock Performer, MSD Ign., Hydroboost, Hyd. Clutch, Flow Cooler WP, Be Cool Aluminum Radiator, Doug Thorley, NV4500 5-Spd, NP-231D, 3.73 F/R Trac-Locs, Rustys 4" Lift, Vintage Red Metallic, Black Interior and 33X10.50X15 BFG, FiTech400 to come - IN PROCESS Bling Bling Cha-Ching
Old 03-12-2009, 03:29 PM
J.J.'s Avatar
J.J. J.J. is offline
Welcome from California
Joseph
77 Cherokee 4 door
