  #41
Old 02-01-2009, 01:22 PM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
Welcome back Peter! Good to see you're still around!
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 02-01-2009, 05:07 PM
Peter Matusov Peter Matusov is offline
Thanks Lindel,
I never went away - been lurking every now and then.
My son took the long Rangie away, and I never quite got used to driving a Volvo to work; the Disco on 32s takes just as much gas to drive to work as the Wagoneer, but the Wag rides much nicer. So...
... 'soon as I get back from the sandbox, I'll devote some time to get back from a FSJ owner to an FSJ daily driver again.
Peter Matusov /68 Wag/95 Range Rovers - SWB & LWB/96 Discovery - white and green/01 XC70
AK6PM
Old 03-07-2009, 04:43 PM
OutdoorNM OutdoorNM is offline
Holly for 1986 Cherokee?
Hi Folks,
I just acquired a 1986 Cherokee 160K with auto trans. When I couldn't get the vehicle started I took it to the local jeep(dealer) shop. They wanted $1000- for a rebuilt carb(no labor, just the carb)..... I eventually got a local garage to slap on a carb from the junk yard and do a bunch of other stuff for $600- It is now slow to start up, but once warmed up runs like a champ. I'm new to Jeeps, but have heard the carburetors can give you a lot of problems. I saw an add for 'remanufactured' Holly Carbs for my vehicle for about $525- which can be ordered thru' Auto Zone in 2 days.
I was wondering if I should consider the Reman' Holly should I have trouble with my existing unit? Your advice would be appreciated!
Lincoln
Old 03-07-2009, 05:52 PM
Lindel's Avatar
Take a look at www.summitracing.com or www.jegs.com for Holley carbs, and you should be able to get a remanufactured carb for $300 at the most. I'd start looking elsewhere to get your parts.
You'd be money ahead to pick up a shop manual of some kind and do the work yourself.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 03-07-2009, 07:40 PM
Thanks, Lindel
I will check out those sites. I plan on doing a lot of my own rebuilding, but I was desperate to get the jeep functional.
Lincoln
Old 04-02-2009, 05:16 PM
TheJeeper's Avatar
TheJeeper TheJeeper is offline
Hey speaking of Holleys, I need a rebuild kit for a model 1920 on my '65 with a 230. Any of you guys know where I might get one?
'65 J200: 230ci., T90A-1, built with T90J input shaft, Spicer 18, 2.47:1, D44s: 4.27s. 31x11.50x15 vintage Star M/Ts
Regarding a manual valve-bodied auto... "To me that's like trying to play a fiddle with a sawzall."
Nothing in written by me in ANY post can be used without my written consent.
~Eli's Jeep Supply~
Old 04-09-2009, 11:56 AM
I think Ristows thread on his Holley should be linked over to this one.
http://www.ifsja.org/forums/vb/showthread.php?t=100852
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
