Old 02-10-2004, 01:42 AM
J10Mike's Avatar
J10Mike J10Mike is offline
Delightfully Incompetent
to start off, my horn worked somewhat depending on where the steering wheel was turned. it started getting worse and now only the relay clicks. i replaced the relay and still no horn, i did all the testing per tsm and found that the actual horn and relay work fine. it's the switch inside the steering column.
question is: are those switches still available new?
if not, i'm going to get an aftermarket horn button switch instead of tearing up my steering column. any opinions?
www.j10mike.com
Old 02-10-2004, 04:21 AM
Fornesto Fornesto is offline
I didn't replace my horn switch, but basically rebuilt it. My entire assembly had been lost/removed. If your relay is clicking, your horn assembly in the wheel is working, no need to touch it. You should check the wires leading to your actual horns under the hood. If you do need to rebuilt your horn assembly, you will need a spring and a brass screw from the hardware store. If you have any questions, holluh!
Old 02-10-2004, 04:28 AM
J4GRAND's Avatar
J4GRAND J4GRAND is offline
J4000 Restoration Specialist
Missed this post earlier. Make sure that your relay and horn itself are grounded to the inner fender. Had the same problem on my J4000- push horn pad and hear relay click- and it turned out to be rust under the horn mount itself. Wired brushed and she now lets out a healthy "JEEP-JEEP".
BTW, was '73 the last year for the older/military-sounding horn? I love the JEEP-JEEP sound.
Patrick V.
MEMBER #14
78 Cherokee Chief WT "Old Blue" 360 V8 4V TH400 QT
05 Jeep Grand Cherokee 3.7 V6 5 speed automatic with new QT
Old 02-10-2004, 04:38 AM
J10Mike's Avatar
let me rephrase this....the relay is no longer clicking when using the horn button. after using volt meter and jumper wires per tsm for testing purposes, i concluded that the horn does work very well and the relay is doing it's job.
fornesto, just rebuild the horn switch? meaning: pull the steering wheel? i did notice is that there isn't any spring left in the horn button either.
www.j10mike.com
Old 02-10-2004, 02:47 PM
J10Mike's Avatar
any other opinions?
www.j10mike.com
Old 02-10-2004, 02:52 PM
Chevelleguy's Avatar
Mount one of those cheesy white plastic horn buttons to your dash.
Old 02-10-2004, 03:02 PM
Twinhuey Twinhuey is offline
Does not have to be white!! Mine is red!!LOL!!
1976 Cherokee WT, stock except for the slightly larger tires. This is my first jeep so I am currently enrolled in the Learn to fix it as it breaks program!!
Old 02-10-2004, 03:16 PM
2MUD-IN 2MUD-IN is offline
Get one of those 99-different tune horns with PA speaker. Then you can yell at all the crazy drivers on I-270 around Manchester road.
Thanks,
2MUD-IN.
____________________________________
Old 02-10-2004, 03:37 PM
J10Mike's Avatar
hey 2mud,
i'm one of those crazy drivers on 270. round trip from imperial to earth city. where are you?
www.j10mike.com
Old 02-11-2004, 03:25 AM
I "rebuilt" my horn for about $1.50 at OSH -hardware store. You will have to pull the steering wheel, but its not that bad. Just by the plate replacement tool first at Kragen, NAPA (~$10). Otherwise, you will never get the wheel back on. I used a 1 1/2" X 1/4" spring (OSH)and figured I could cut it down. The spring sits in the little sleeve. Second, buy a brass screw at OSH. The screw has to fit inside the spring. Use brass because it conducts well. You will have to cut the screw down slowly so that it fits. The spring provides tention against the brass ring while the wheel turns. It doesn't push the horn pad back like other vehicles. There is a descrete plastic foamy pad that does this. When you push the horn, the brass ring contacts the brass screw and completes the circuit. Experiment with a couple screws and springs and you should be going in no time. Study how it should work and figure it out first.
Good Luck!
