Old 11-26-2006, 11:39 PM
4x4fEvEr's Avatar
4x4fEvEr 4x4fEvEr is offline
9.5 seems to be it. got my 203. those things are huge. so 435 to my collar from the 208 setup into my 203 that i just got then get my NWF adaptor kit to bolt on my 205. excellent
Old 11-27-2006, 07:12 AM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Ah, but you are going to miss all the fun of stripping/rebuilding the range box to redrill the front of the case
If you haven't seen it, NW Fab has a manual on the basic process you will need to follow at http://www.northwestfab.com/203-205adaptorinstall.html
Old 11-27-2006, 07:37 AM
orangecherokee's Avatar
this is a good thread and needs a sticky i think. also, if anyone has a 32 spline 203 floating around for cheap let me know. me wanty.
Old 11-27-2006, 08:05 AM
elbastardo elbastardo is offline
You can get any 203, and buy the 32 spline seperate.
Old 11-27-2006, 09:41 AM
yeah i could but i'm not pressed for it right now. plus it eliminates the hassle of buying more parts.
Old 11-27-2006, 05:38 PM
Brad W.'s Avatar
Brad W. Brad W. is offline
I have some sort of np203 gearbox floating around here, i'll try to dig it out from under the bench and check it out. If its a 32 spline, i'll let you know Nick, I have no use for it at this time. I'll probably go Klune if I decide I need more gear.
Brad W.
1979 wag "Nightmare"
**project shelved indefinetly**
m715 ex-firetruck
**project shelved**
2001 Dodge Ram 2500 "Project Juggernaut"
24v-CTD/NV-4500/quad-cab/4x4
4" straightpipe, rollin on beadlocked 37's.
Old 11-27-2006, 08:41 PM
4x4fEvEr's Avatar
crossmembers
moving forward on this doubler. what would everybody do for the crossmember to support the 203 and 205? could u reuse the 203 or 205 doubler, drill and cut it to mount to the frame and go on with life or whip out some round or square tubing and fab one up? do you need two crossmembers one for each tcase?
Old 11-27-2006, 08:59 PM
Elliott's Avatar
Cowboy Up
I think there is a good crossmember thread on here to search up in this part of the forum, can't remember if it covered doublers or not. I was gonna try and just fit two OEM crossmembers... but have no idea if that'll work. Maybe you can skip the crossmember under the tranny to 203 and just move it to locate under the adaptor foot between the range box and 205.
Brad, if the adaptor is still bolted to the front of that GM203 and it only has 4 bolt holes for the transmission it will be 27 spline, if there are 6 bolt holes for the tranny it's gonna be the 32 spline.
Old 11-27-2006, 10:38 PM
that would be the tits if it was. let me know.
Old 11-28-2006, 01:35 AM
oldyellowwagoneer oldyellowwagoneer is offline
On the subject of 205's who has the bearing od and id of the input bearings on a big bearing 205 case and on a small bearing 205 case?
Dennis
“Don't do anything by half. If you love someone, love them with all your soul. When you go to work, work your *** off. When you hate someone, hate them until it hurts.” Henry Rollins
Old 11-28-2006, 10:45 PM
Elliott's Avatar
Cowboy Up
Dennis
Ford NP203 Input Bearing Dimensions: ****(these are the very same dimensions and part # as the ‘85+ NP 205 input bearing, ref NAPA #BRG210NRJ @ $103.99)
Old 11-29-2006, 03:34 AM
Thanks Elliott, I guess thats the same as the t400? now how bout the small one? Dennis
Old 11-29-2006, 02:45 PM
Elliott's Avatar
Cowboy Up
Maybe someone else here has a small bearing or small bearing case they can get a meaurement off of, I only have the large case. Are you just trying to figure how much to have the case bored up to fit a large bearing?
Old 11-29-2006, 09:19 PM
No, I think I can get a bearing that will let you put a big bearing input shaft (like a T-400 or ford) into a small bearing case thereby eliminating the machine work. Dennis
Old 11-29-2006, 10:35 PM
4x4fEvEr's Avatar
you got all the good info elliot.
ive got everything for my drivetrain but the T176 bellhousing have a hard time on that one. i want to get this setup in my rig.
Old 11-30-2006, 07:29 AM
Elliott's Avatar
Cowboy Up
I'd look around or post here in the wanted section for a 176 bell, I got ming for ~$45 but if you are in a hurry you can buy one new from www.4wd.com for ~$200.
Old 11-30-2006, 10:04 AM
4x4fEvEr's Avatar
yeah im def not in a 200 dollar hurry, i can wait.
once i get the bellhousing, what clutch do i get? i was reading some stuff from OC and i think scotty about using a clutch meant for a hydraulic slave cylinder with a clutch design for a straight linkage setup being different. mines gonna stay with the linkage so im not real sure what to get. i thought i seen it somewhere people using a clutch out of a mustang.
Old 11-30-2006, 10:48 AM
Elliott's Avatar
Cowboy Up
If you use stock Jeep clutch components all you need is a Ford disc and an adapted input bushing for the crank available at Advance Adaptors. I can't advise you on hydraulic bits, but if you anticipate a lot of frame flex you might want to go that route. I've done just about as much shifting without using a clutch pedal as I have with one so in the rare case my linkage might bind up I'm not going to worry about it personally... but that's just my feeling about it and it might change if my butt was hanging off a cliff
Old 11-30-2006, 01:33 PM
4x4fEvEr's Avatar
ok a ford disc from anything v8 or one from say whatever came in front of the np435. i seen the bushin on novak and advance ill be ordering that next
Old 11-30-2006, 03:16 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
I believe a disk from an early 80s 5.0L mustang with T-5 should have the disk you want. You're looking for an 11" (10.5" if you can't find an 11") disk with a 10 spline 1 1/8 (I think) input.
aa
