Old 02-26-2020, 01:32 PM
iriddles iriddles is offline
clutch/trans noise
I need some help diagnosing this noise! Several weeks ago I got in my '70 J2000, 350 V8, T-15 3 speed to go to the dump. Cranked her up, idled for a minute, then depressed the clutch pedal and there's an awful growling noise. Let clutch pedal out and it went away. Some times in my short trip the noise would appear when the pedal was depressed. Soon as I start to let the pedal out it goes away. No noise while shifting or in neutral. I thought it might be the throwout bearing but it doesn't do it every time the pedal is depressed. I re-adjusted the clutch linkage and gave it a little more free play (within specs). Now there is a slight, faint rattle when idling in neutral as well as the occasional growling when pedal is depressed. Trans was rebuilt about 8 yrs. and 4,000 miles ago by a professional jeep mechanic. Trucks been put out to pasture so there's been no hard work or heavy lifting. Anybody got any ideas?
Old 02-26-2020, 02:51 PM
"No noise while shifting or in neutral" - you mean no additional noise? Noise when you apply the clutch that goes away when you release it is consistent with a bad throwout bearing. The clutch should be engaged when you shift, so you'd have the noise while you shift.
Old 02-26-2020, 02:53 PM
SJTD SJTD is offline
If it only makes noise when you're on the clutch pedal seems it gotsta be the throwout or the pilot bearing in the crank end.
Unless maybe the disc is coming apart and pieces are sometimes rolling around between the clutch and flywheel and pressure plate.
Sic friatur crustulum
Old 02-26-2020, 03:58 PM
No noise when shifting! Aside from noise, trans performs perfectly. After adjusting free play and hearing the faint rattle, there may be something coming apart!
Engine ticking noise Obi-Wan General FSJ Tech 8 11-21-2013 03:58 PM
Engine noise, 4.0 swap???? Mex in the city General FSJ Tech 5 11-24-2008 04:00 PM
GW - Loud noise.... like a groan or a rubbing? cate General FSJ Tech 4 09-27-2007 10:26 AM
HELP! Noise with hubs locked and we've got a blizzard in KS!! 4LoTJ General FSJ Tech 14 12-06-2006 08:25 PM
debug a noise problem GED General FSJ Tech 7 05-12-2006 07:33 AM
