Old 02-18-2020, 03:13 PM
CLL CLL is offline
Leaky electronic ign!?
Hey all, I've got a 1980 J10, and just noticed the Motorcraft unit on the drivers side fenderwell has some clear gummy drool running back down on the sheet metal under it. Everything seems fine with the truck otherwise. What's the heck is going on? Thanks, Chris
Old 02-18-2020, 04:09 PM
babywag babywag is online now
When modules get too hot they can melt goo out.
Could be from an old module failure too?
Old 02-18-2020, 06:46 PM
Jeeper555 Jeeper555 is offline
Take a closer look, hope those are just some kind of grease.
Old 02-19-2020, 12:22 PM
The modules are "potted;" that is, the circuit board and components are put into the aluminum case which is filled with liquid plastic, known (not surprisingly) as "potting compound." The module is mostly a big transistor that handles the coil switching that was in prior years handled by the opening and closing of the ignition points. If something goes wrong, the module overheats and could melt the plastic block.
electronic ignition for 258 or no? bruner1981jpce General FSJ Tech 9 07-08-2011 08:48 PM
Leaky exhaust valves at 32,000 miles Serious Johnson General FSJ Tech 3 11-29-2010 06:45 PM
74 points to 80 electronic 360? jeeperx2 General FSJ Tech 13 09-22-2009 07:58 PM
327 electronic ignition the jeep General FSJ Tech 3 05-02-2008 12:45 PM
Electronic Ignition-which one JOHN D General FSJ Tech 5 11-03-2000 09:58 AM
