Old 02-16-2020, 09:01 PM
Full Size Jeeper's Avatar
Serehill tailgate harness question
I'am working on getting my tailgate back together. I bought a Serehill harness from someone who did not use it. Anyway, His instructions don't say anything about how to wire in the safety switch for the window. I do see a red wire with a disconnect. Was thinking maybe this is what that wire is for if you want to use it. Can anyone confirm this. Also this harness was originally bought in 2013 and never used. I opened it up and something is not right. Somehow when it was built, the switches were installed in the wrong place. The dash switch was installed back by the tailgate and the tailgate switch is up front. I will have to cut them out and fix that.
1978 Wagoneer
Mods:
Old 02-16-2020, 09:03 PM
This switch is up front near the dash.
1978 Wagoneer
Mods:
Old 02-19-2020, 06:51 AM
Can you not just unscrew the switches and swap them? Do you have to cut?
I didn't wire in the safety switch when I installed mine so I cant help you there. I did have to add a good amount of wire to get the wiring inside the cab for the dash switch. It was a good 3' too short. He said he had made a mistake with a jig or something.
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
1989 Jeep Grand Wagoneer 360
Old 02-19-2020, 07:41 AM
No, two different style connectors. I already put the tailgate switch to the back. I'am going to wait to fix the connectors for the dash switch. I want to make sure I have enough wire to put the switch where I want it in the dash.
1978 Wagoneer
Mods:
Headlight harness question Full Size Jeeper General FSJ Tech 11 07-25-2018 03:59 PM
wiring harness question jeeper63b General FSJ Tech 2 12-27-2010 12:48 AM
Tailgate glass parts question with diagram Maryland Rick General FSJ Discussion 5 12-22-2010 02:05 PM
Another...Tailgate wiring question 70Wangoneer General FSJ Tech 0 02-16-2009 11:14 PM
Electric question - wiring harness V8/6cyl sportsidedan General FSJ Tech 1 08-15-2007 07:11 AM
