Old 01-27-2020, 06:21 PM
e_digg's Avatar
e_digg e_digg is offline
Exhaust Manifold Bolts
I have a 91 360 with stock headers. I am looking for the exhaust manifold bolts and I understand they are different sizes but the 3/8" inch bolt seems very small in the manifold hole itself. The 5/16" bolts fill the space. What am I missing? See pic to get a better understanding.
1991 Grand Wagoneer
My 91 Phoenix Build Thread
Old 01-27-2020, 08:03 PM
babywag babywag is online now
not missing anything...
for whatever reason they used 2 different sizes.
Old 01-28-2020, 01:43 AM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
Why would you say a 3/8" bolt is too small and a 5/16" bolt fills the space better? That makes no sense. 3/8" is larger than 5/16"! I think you have the two sizes confused.
The space around the bolt allows for thermal expansion of the exhaust manifold. Big chunks of cast iron expand quite a bit when they get as hot as exhaust manifolds do, and the manifolds would crack if they were not allowed to shift and "creep" around the bolts as they expand and contract. The bolt holes in the center of the manifolds are smaller because they are there to hold the center of the manifold in place while the far ends of the manifolds expand and contract. That is why the bolt holes out at the far ends are larger than the bolt holes in the center.
You see this even more on big long inline sixes and inline eights.
Old 01-28-2020, 05:19 PM
e_digg's Avatar
The end or outer ports bolt holes are 5/16" but the hole in the manifold that the bolt goes through is more than 1/2". The inner ports are 3/8" and the holes in the header are about 1/16" bigger in diameter. I am thinking that I need to try and find something like this to make it work (less spring of course).
1991 Grand Wagoneer
Old 01-28-2020, 09:30 PM
do whatever you wish but normal bolts work just fine.
Old 01-28-2020, 10:15 PM
asphaltrockdweller's Avatar
Yeap!
Old 01-29-2020, 03:11 PM
gopher_6_9 gopher_6_9 is offline
This.
They seal fine if your manifolds are true.
1983 Cherokee W/T
360
727
Old 02-10-2020, 12:47 PM
Jeep Doctor
That clearance is to accommodate the expansion/contraction of the cast-iron manifold. You need a strong washer under the head of the bolt to put appropriate clamping-force on the manifold.
Old 02-10-2020, 01:15 PM
nograin's Avatar
nograin nograin is offline
See if you can find a set of original bolts. Might be the same as used on other AMC engines. The tip of the bolts is hollow. That detail apparently was worth the expense to insure the bolts maintained proper tension in threads.
Exhaust-Manifold-Bolts-3527
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 02-10-2020, 02:21 PM
Jeep Doctor
Chrysler did NOT think it critical enough for the 5/16" bolts that they sold over the counter in 1998 to be hollow, though (the 3/8" replacements were still hollow).
I think the main usefulness of the drilled-centers on the bolts is to give you a nice pilot-hole for an EZ-out to remove them when they break off in the heads...
Old 02-10-2020, 04:21 PM
nograin's Avatar
Chrysler probably couldn't care less about the AMC engines in '98.
Seriously, I thought I had a couple web links about the history and reasons AMC went this route for those bolts.
Can't find them right now.
edit: Well here's a few.
http://theamcforum.com/forum/forum_posts.asp?TID=26371&PID=307615&title=exhaust -manifold-bolts#307615
http://theamcforum.com/forum/forum_posts.asp?TID=73710&PID=666875&title=390-exhaust-manifold-bolts#666875
http://theamcforum.com/forum/forum_p...d-bolts#805075
If the information is correct:
Maybe as early as 1969 AMC started using these bolts, and was a service replacement very early in the 70s.
Made by Rockford and at least some have special head markings (I'll have to look at mine again)
Grade 5, Zinc Plated and "waxed", 3/8-16, Class 3 thread, drilled thread end so they wouldn't loosen.
Use with a thick strong washerunder the head .
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
Old 02-10-2020, 05:22 PM
e_digg's Avatar
NO! There is an extra 1/4" gap on the outer ports and that cannot be for expansion. Waaaay too much! You are correct on that with the inner bolts and there is minimal clearance there.
1991 Grand Wagoneer
Old 02-10-2020, 05:47 PM
Jeep Doctor
Well, the outer ports used a 3/8" bolt up until '78, and the passenger-side manifold design remained the same. Perhaps when they switched to the 5/16" outer bolts in '79, they did not change the exhaust-manifold blueprints for correspondingly-smaller holes on the outer ports, or perhaps your manifolds came off an earlier truck?
Old 02-11-2020, 12:03 AM
FSJunkie's Avatar
It worked fine from the factory. Just put it together the way the factory did and it'll work fine. Problem solved.
Old 02-11-2020, 06:09 PM
e_digg's Avatar
Thanks for all the input. I'm going to go and get some grade 8 bolts and use those.
1991 Grand Wagoneer
Old 02-15-2020, 02:50 PM
I used grade 8 bolts, lots of antiseize, and nord lock wedge locking washers.
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
1989 Jeep Grand Wagoneer 360
Old 02-16-2020, 09:33 AM
i believe the bolts were hollow so they would stretch more easily upon torque down,which keeps them snug thru the temp swings.
i use plain bolts when the hollow bolts are not useable.
anyone that has fought the older 3/8' bolts into position appreciated the move to the 5/16 bolts.
Old 02-16-2020, 10:18 AM
I have just regular ole bolts on both my GWs.
88 even has headers, no leaks, have stayed tight, etc.
I do recall back in 2005 a couple bolts broke on removal.
The hollow bolts made for super simple removal.
Old 02-17-2020, 10:12 PM
Rod2's Avatar
Rod2 Rod2 is offline
I replaced my manny bolts with 3/8 stainless steel bolts--not hollow and no problems,
Rod Skaggs
'73 J4000 'WOOD GO' 360, 2100 MC, T-18, D-20, 60-2 rear, D-44 closed knuckle front, Eaton E-lockers both, Pertronix module, AC, PS, '77 Firebird tilt column, Hydro-boost, AirLift bags front and rear, 33x15 Goodyear MTR's, Pacer 15x8 aluminum Bullet Holes, Summit line lock, 3rd brake light
Old 02-26-2020, 01:05 PM
61Hawk 61Hawk is offline
Aren't stainless steel bolts awful brittle?
Broken Exhaust Manifold Bolts AMC4ME General FSJ Tech 11 12-04-2011 09:24 PM
Exhaust manifold bolts w/ end holes? Rich88 General FSJ Discussion 4 04-05-2009 05:15 AM
Size of exhaust manifold bolts DanHS General FSJ Tech 11 06-16-2007 05:39 AM
exhaust manifold bolts Paul General FSJ Tech 14 05-01-2003 08:28 AM
Exhaust manifold bolts J10/J20 Project General FSJ Tech 37 08-26-2002 04:59 AM
