Old 12-22-2012, 09:06 PM
mattmopar440's Avatar
QuadraTrac Aftermarket chains (poking the sleeping bear)
Ive looked around and read alot of chains my QT in the 74 is a jumping and a banging only when Jon drives it tho
So I figured I should get a new one I like the 16% OD option but I've been hearing nightmarish problems with anything aftermaket with the chains Just wondering if I should go find another good working unit and roll the dice. Or Attempt a repair ?????
http://www.bjsoffroad.com/prod-21.htm
87' Grand Wagoneer
80' J10 4BT/AX-15/208
74' J10 Go Grabber Green Sold
Inferior Chevy
Old 12-22-2012, 11:20 PM
Kevin armstrong Kevin armstrong is offline
The chineese chain fixed the skipping problem but when my brother and his son were out at my place for thanksgiving, they didn't want to try "chinese quadratrac chain test hill". I wouldn't let my dog ride up that hill with me. I will give it a mud run by myself soon. Its the last 80' that makes you ponder your true reasoning for attempting this crazy clay cow crap hill. Incredibly, its much easier in the mud. When the wheel speed decreases to nothing is when it gets scary. and its all in the last few feet, when you need wheel speed to overcome the straight verticle clay. The chinese chain is working fine but it sometimes gives me the "WILLYS"
Old 12-23-2012, 12:25 AM
i put that chain in the '74. it's shot already? that jhon,i tell you.....
what'r you doing with that '80 i sold you?
Old 12-23-2012, 12:34 AM
Yea its a different case the other one got lost with the old trans Long story
nothing at the moment on the 80 its in storage for winter 74 is a bit more practical
87' Grand Wagoneer
Inferior Chevy
Old 12-23-2012, 12:49 AM
Jeepguy77's Avatar
Jeepguy77 Jeepguy77 is offline
It may be a bit off topic, but why is it chains seem to go bad so often in qtrac cases? But not in the np cases?
Pierce,
77 J10 454, TH400, D20,
Old 12-23-2012, 01:29 AM
Chain in a New Process is only being used in 4wheel drive QT all the power goes through the chain then to the front and rear axle
87' Grand Wagoneer
Inferior Chevy
Old 12-23-2012, 07:03 AM
When you mention the 16% OD, just a reminder that is a different spool gear too. Good luck finding a MM kit. I dunno about these chains. If you can't get a Morse chain, then one of these is probably better than a busted QT.
Old 12-23-2012, 08:10 AM
bring me that '80 back,i got a J20 driveline i can put in it.
Old 12-24-2012, 02:27 AM
When do u want it
87' Grand Wagoneer
Inferior Chevy
Old 12-24-2012, 11:23 AM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
while they aren't as good as the Morse chains, they are the only option for a new chain. As Flint says, a chinese chain is better than a busted case.
BJ's Off-Road
ryan@bjsoffroad.com
Old 12-24-2012, 01:27 PM
TrenchFoot's Avatar
TrenchFoot TrenchFoot is offline
Ryan, I thought you or someone else said that Crown was working to improve the quality of their chains. Any truth (or proof) to that? If so, are there any markings that differentiate 'gen 1' vs 'gen 2' Crown chains?
'78 Wag, 401/TH400/QT pulling the rust down the road. Chevy 6.2L turbo diesel waiting in the wings...
Old 12-26-2012, 03:08 PM
billyrb's Avatar
BJ's Off-Road
that is what we've been told is that these have a higher quality control than previous chains. No markings that I know of.
BJ's Off-Road
ryan@bjsoffroad.com
Old 12-28-2012, 01:22 PM
kntemplars's Avatar
kntemplars kntemplars is offline
Although I am not as experienced with jeeps, I have only had mine for almost a year, I can say that is seems like morse chains are like finding a good women.....once you stop looking whamooo you find her!
I couldn't resist. It's our 10 year anniversary today. And last month I found a morse chain on Craig's List for $100. On both accounts I am extremely grateful!!
Old 01-15-2013, 08:13 PM
well my QT in the J10 is bad and my spare case I have the chain has over an 1" of play so Ill have to replace the chain
87' Grand Wagoneer
Inferior Chevy
Old 01-15-2013, 10:19 PM
Jeepguy77's Avatar
So what if someone came up with a tensioner of some kind? I read that lack of a tensioner is why the chains don't last compared to modern cases.
Pierce,
Old 01-15-2013, 10:34 PM
mdill's Avatar
mdill mdill is offline
Gone. Not Forgotten.
Modern cases don't run tensioner's either, they also dont run all (100%) of the power 100% of the time though the chain like QT cases do, they only run the front drive line off the chain, so the chain is only really used very little for the most part.
Most have a larger sproket diameter which puts less stress on the chain also.
Home of ADHD project list
1977 J-10 Honcho 360-T15-D20
Old 01-16-2013, 02:29 AM
Jeepguy77's Avatar
OK, I was just thinking that maybe if a tensioner could be built it could extend the usable life of these chains. But Ive never had one apart, and imagine it may be too much work to make one.
It makes sense about modern cases and running the rear through a shaft and not the chain itself. Im not knocking the qtrac, I was just curious to see if something like this could help.
Pierce,
H.B. 2186 Anti Aftermarket Bill Randyzzz Land Use Information 0 02-11-2009 01:28 AM
