Old 11-18-2012, 10:10 PM
Chief Gunner's Avatar
Chief Gunner Chief Gunner is offline
Engine build ( a learning thread)
Everyone,
I am looking to do an engine rebuild in the next few months. I am interested in basically a stock rebuild, nothing crazy. Overall, I am happy with the engine in stock form. It has pleanty of power and torque for waht I need. My current engine is burning oils quite a bit, but still runs pretty strong for over 180,000 miles. My buddy (4X6 wag on here) has a spare engine we pulled from his "donor" wagoneer. The engine had some type of internal damage that we wont know about until we pull the engine apart. The goal is to rebuild this engine then swap it out with my current engine to be rebuilt when needed. I have talked to Ristow a little and he has given me a lot of information, but I want to hear from everyone as well. What would you do and why. Again, I want this to be a learning thread not just a "my way is better" thread. Why would you choose what you did. My buget is a little under 5k, but that includes a transmission bebuild and some other items for the jeep that I need to do. So far, this is what I am looking at as far as parts:
drivetrain mount kit KIT-7553 BJs Offroad 105.00
freeze plug 381-8001 BJs Offroad 17.00
lower gasket set BJs Offroad 23.80
upper gasket set BJs Offroad 51.00
camshaft bearings SH671S BJs Offroad 28.00
connecting rod bearings CB960P-8 BJs Offroad 56.00
piston rings E301K BJs Offroad 85.00
Keith Black piston 2225C BJs Offroad 305.00
main bearings MS1041P BJs Offroad 95.00
Edelbrock timing chain 7818 BJs Offroad 65.00
Edelbrock intake manafold 3731 BJs Offroad 265.00
Edelbrock cam 7132 Summit 270.00
Timing Cover Kit BJs Offroad 245.00
This is just to start. Let me know what I am missing or if there are better deals that you know about. Thanks in advance
The War Wagon: 1986 GW- SOA/SF on 33X12.50's, 360/727/NP228, CS 144 Alt, OBA
Wife's DD: 2012 Ford Focus SEL
My carbon foot print is bigger than your's.
WWW.SOCALULTIMATE4X4.COM
Old 11-18-2012, 10:21 PM
REDONE's Avatar
REDONE REDONE is offline
If you've already spoken at length with Ristow, then you've already heard my recommendation and the best argument made for it by the person most qualified to make it.
Increase compression ratio, either by decking the block or using taller pistons, but increase your compression ratio to 9:1 at least. It increases power AND efficiency. I have no idea why the manufacturers used rediculously low compression ratios. I speculate that they assumed taking lead out of gas meant that eventually gas would have lower and lower resistance to detonation or something, but honestly. 9-9.5:1 will give you more power and milage and take away nothing in reliability or longevity.
79 J-10 - The Money Badger!
304/T18/D20/D44s
What's been did:
Holley 4160/Ede' S.P.2.P.
MSD Streetfire based TFI
Custom-hack gauge cluster
Razor swap
2 knob tape deck!
3" homebuilt lift
Half a hillbilly paint job
Old 11-18-2012, 11:17 PM
yep, what he said. I like the idea of decking the block. I will have to figure all that out, but I think it makes sense to me.
Old 11-19-2012, 05:50 PM
Just an opinion since I've got lots thought I'd spend one here. If Ristow has given you his game plan I'd trust it. Only thing I would question is the pistons. Don't know the full line of Keith Blacks stuff but when I see/hear Keith Black, I think forged pistons. IMHO forged pistons are an overkill($$$) hassel for a street motor. Great for racing but not so much for practical normal use. If KB also sells cast pistons for a 360 then I'd go with it, if forged only I'd look elsewhere and save some money and smoking/oil use grief.
Old 11-19-2012, 06:22 PM
WHSII's Avatar
WHSII WHSII is offline
Hack-Priss
I personally would let the machine shop supply the cam bearings and freeze plugs. They will warranty what they install. Unless you talk with them first, and they agree to your sections. They buy many sets per month, and I bet they can beat your price...
Depending how you feel about assembly, the machine shop should put it all together, more money, but if you do not have the specialty tools needed, it might be a wash. Ie torque wrench, ring compressor, valve spring compressor, etc.
I would consider balancing, it is not a necessity with a stock engine, but is is as good an insurance as to longevity to an engine rebuild as it gets.
BJ's is great, but I would also price quality auto parts stores for the main parts, all can get the rebuild parts. The machine shop probably gets a major discount because of all the parts they buy.
I like Joe's thoughts on pistons, If you are building a stock engine, go with stock.
With a rebuild of an AMC engine, I would make sure the rockers and bridges, were replaced, even if you went back stock. Of course, new lifters with the cam.
There are many many ways to do this, and many many ways to spend money.
I would first find a quality machine shop and find out what they can do for you.
As far as building your buddy's damaged engine, you might get bitten. a worn engine, vs an internally damaged engine could be many $$$ extra to rebuild. I would go with what I know.
Just my thoughts...
WH
Herbina 1987 Grand Wagoneer
Old 11-19-2012, 08:02 PM
J20 project's Avatar
http://www.summitracing.com/parts/MEL-MTC-1/
This Melling cam specs out pretty much the same
http://www.summitracing.com/parts/MEL-40400/
This Melling timing set does the same..
Sometimes you are just paying for a name.
My 401 cranks w/ this set up.
J20
BP Drivetrain...........
775-537-7918
Old 11-19-2012, 08:08 PM
REDONE's Avatar
J20
You put a Chevy cam and timing chain in your 401?!?!
The Melling MTA-1 is discontinued, but thanks to Ristow I know it's same enough to the Ede' Performer, and I've heard another say it's still made but by Sealed Power or something. Summit makes a double roller timing set as well, but I've heard it's got oiling issues, others not as bad. I'd go with what Ristow says, he seems to crap out another AMC rebuild every other month, that's about 24x as often as me.
304/T18/D20/D44s
What's been did:
Razor swap
2 knob tape deck!
3" homebuilt lift
Old 11-19-2012, 08:16 PM
The PIG Smith's Avatar
King Browless
I would shop at BullTear (especially for the timing chain cover) and Z&M Jeeps as well for these parts
Bryan Smith
Originally Posted by Jayrodoh
Originally Posted by Lindel
Old 11-19-2012, 08:26 PM
Just representative friend.....The Melling might not be around now...
http://www.jegs.com/i/Edelbrock/350/2132/10002/-1
How about that for your Edelbrock set...179.99 for the amc?? Says 2132 rather than 7132 though
Good Luck
775-537-7918
Old 11-20-2012, 06:42 AM
jeepsr4ever's Avatar
www.Bulltear.com Chief
KB pistons are now made in India and are known for the last year and a half to fall apart. I dont care where you get your pistons but dont sell yourself short buy some good forged pistons for street use and youll never have to worry about them and youll get the same performance out of them as a cast piston but they will outlast the cast pistons by many times.
AMC/Jeep Forum
Old 11-20-2012, 07:29 AM
i've bought a lot of parts from maddogracing. good prices and parts. free shipping a lot of the times as well.
melling mta1 in stock. 100.00 you'll need to get the lifters. about 60.00
http://www.fastengineparts.com/amc-j...shaft-cam.html
full clevite bearing kit. 129.00
http://www.fastengineparts.com/amc-j...3-304-360.html
full gasket kit. 65.00
http://www.fastengineparts.com/amc-j...asket-set.html
look at the Offy Equa Flo intake. it's 40 bucks more. i put one on my 401,and i like it a lot. it is a mid range intake,but i really don';t see a loss of idle. this motor,in a lited cherokee on 33" MT's has delivered over 15mpg averages.
http://www.summitracing.com/parts/ofy-5917
these engines don't have to be as expensive to rebuild as some think. i can tell you where to get the good parts,and what parts to avoid.
the parts listed above save you almost enough to start thinking about some better rockers. people will say they're overkill on a stock/mild motor. i disagree. over built is good. also,roller rockers maintain the lift ratio thru the arc. stock rockers do not,the ratio changes as the tip rolls over the valve. the roller tip greatly enhances valve stem life. the stock rocker scrubs back and forth on the valve tip.
i have 1.7 ratio roller tips in my 401. increased lift,with negligible affect on duration.
i would pass on the new timing cover,and refurb the stock one,unless real tore up in the pump cavity.
you will never see the intake valley oil line on one of my motors. that little mod has blown more motors than it has "saved".
Old 11-20-2012, 12:03 PM
blazer3664's Avatar
blazer3664 blazer3664 is offline
Lots of good advise here.
Thanks for sharing that bit about KB pistons jeepsr4ever, had not heard about that yet.
As far as upgrades while you are at it, I agree with Ristow........
Good "bang for the buck" right there. (higher ratio rockers) Has the same general effect as a bigger cam, without the rough idle.
I would like to here more about this though.....
I thought that was supposed to be a good thing?
Not so sure there is really a problem with the factory set-up, since many of these engines go 1-200k just fine. On the other hand, my 401 was killed by oil starved rear rod bearings. My understanding is thats what the oil mod is SUPPOSED to help prevent.
Is there something builders are doing wrong when they install it, or is the mod itself not right?
While the whole oiling thing is on the table, what about the restricted oiling pushrods that Bulltear sells? Might help keep some additional oil pressure down low since the roller rockers wont need quite as much as the factory ones.
EDIT....
Just checked on those pushrods, they are actually listed as (increased crank oiling).
per their site...
with a gold finish and a through hole that is .015" smaller than stock for increased oiling to the crank!
Jim
modified flares, removable top, OBA w/200psi tank,
LQ4, 4L80e,NWF doubler w/upside down 203
SOA w/ D44s F+R for now
H1 wheels+tires (cut), hydroboost brakes
custom shackle flip
W/F150 springs
-----Coming Soon-----
snorkels,
OX'd D60/14B-FF
Old 11-20-2012, 06:01 PM
i'm not convinced the external line is needed or "saves" a high performance engine.
especially on a daily driver. i've pulled amc's apart that showed no accelerated wear at the rear of the motor.
you pop that line,or have a fitting come loose and you will lose the motor before you know what happened.
if i were to modify the oil system i would be more inclined to link the two lifter galleys together at the rear of the block. but again,it's an external line and comes with risks.
the output to block hole is about 1/2" on these blocks. the galley running up to the lifter valley junction is 1/2",and the lifter galleys are about 1/2" as well. granted,the bottleneck is the lifter galleys,the lifters block about half of its' diameter.
but even there,at 50-60psi,that is a lot of oil volume going through there.
it would be interesting to put an oil pressure gauge at the rear of the block,on the lifter galley and compare readings at the front and rear of the oil system. i have a couple motors in the garage,i should do that test with some thin weight oil.
The BigRed Build Thread Red20 Off-Road FSJ Tech 20 05-01-2012 09:51 PM
Starting my build thread for Megasquirt shackwrrr General FSJ Discussion 26 09-15-2010 08:31 PM
