Old 05-22-2012, 01:03 AM
Blake Blake is offline
Suspension limiting chains (chains, not straps)
So long story short I fabbed up some bolt on brackets and installed some limiting chains on the front of a 'cruiser.
I know you are supposed to use straps not chains because straps will 'give' a little rather than 'jolt' like chains will. Using chains because we are leaving for a trip to the sand dunes tomorrow and we simply cannot locate any straps locally, so we must use what we have on hand.
Just wondering if anyone has any real world experience with using limiting chains rather than straps?
Old 05-22-2012, 06:56 AM
j20brett's Avatar
j20brett j20brett is offline
Plenty of rigs have used chain center limit devices before, dont think you will be hurting anything. They just wont give
"Kaiser" - 1981 J20 113" WB - 360 w/ hei/727/208-spooled hp60/detroit 14blt w/5.13's - 42's/CS144/Taurus fan/flatbed and roll bar
Future mods - 6.0l chevy
Build Thread
Fight Crime...Shoot Back.
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 05-24-2012, 08:28 AM
jtr's Avatar
jtr jtr is offline
I used to run one on my old waggy, only noticed it at higher speeds in the whoops.
Jeep is gone ~~ Ranger cab truck in the works
393W/C6/203-205, HP60, 14B, 12 bolt H1s, 40" Pitbull Rockers, full hydro, 4 link rear
Build = http://www.pirate4x4.com/forum/showthread.php?t=973973
Old 05-24-2012, 07:02 PM
Stuka's Avatar
Stuka Stuka is offline
If you are going at speed in the dunes, make sure they are not too short. Or you will find yourself using them at the wrong times.
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 05-28-2012, 05:51 PM
I thought I would answer my own question.
Sorry that this isn't FSJ tech, but none the less, it does apply.
Limiting chains work fine. My buddie's landcruiser weights in at over 6k lbs and he took jumps like this ALL DAY at 50MPH with 6 passengers with no problems.
The limiting chains held up great and believe me, they were WELL used all weekend. They clank around a little, but you can't hear it from the inside of the truck.
Old 05-28-2012, 06:12 PM
cmelo's Avatar
cmelo cmelo is offline
Got a pic of how you mounted them? Also what grade chain you running? I was thinking about just plating a small section of frame and bolting a chain to that, or a couple simple tabs on either end.
79' J10 360/T18/D20- Locked & bobbed on 35s
Old 05-28-2012, 11:45 PM
Well this was on a landcruiser, not a FSJ, so the mounting is pretty much irrelevant on here. I actually used factory bolt holes on both the lower control arm and underneath the frame. Toyota made adding limiting straps/chains very, very easy on a 'cruiser.
Old 05-29-2012, 09:56 AM
cmelo's Avatar
I was talking about what you did on your jeep
trailer talk, chains or straps? (now with pics) youngjeeper Off-Road FSJ Tech 43 11-13-2003 02:24 AM
E-brake cables = suspension limiting straps loborph General FSJ Tech 1 04-15-2003 04:24 AM
(TOM) What FITS and What HITS.... Lift / Tire Combos River Beast Suspension and Steering 40 11-05-2001 12:32 PM
