Old 02-24-2011, 07:08 PM
Mr.Wagoneer's Avatar
Mr.Wagoneer Mr.Wagoneer is offline
Exclamation 83 Intake Manifold hole?
Today I was snooping around the engine bay in the Wagoneer going over some regular check ups, and decided to double check all of my connections on the intake Manifold, wall going over the connections I noticed that there is a threaded hole with nothing in it behind the Thermostat housing offset to the left a little bit or passenger side, It's not the Temp Sending unit, That's installed and offset to the right or drivers side of the engine. Unfortunately it's in a spot where I'm an able to take a photo for reference so any thoughts as to what should be there are welcome! The intake manifold is stock W/EGR and Emission equipped for the AMC 360
Thanks!
Year: 1983
Make: AMC/Jeep
Model: Wagoneer
Trim: Limited
• AMC 360 5.9 Liter
• MotorCraft 2150 2 BBL Carb
• TF-727 3 Speed Automatic
• NP-229 Select-Trac Full/Part time transfer case
• Dana 44 Front Driver side drop AMC 20 Rear
• 109 in. Wheelbase
• 5975/6200 Lbs GVWR
• Manufactured in Toledo Ohio
Old 02-24-2011, 07:26 PM
badaboom's Avatar
badaboom badaboom is offline
Emission Parts
Ported Vacuum Switch
1981 Jeep J10 Laredo, 401-V8, 625 Carter, Lunati 262/268, Edelbrock Performer, MSD Ign., Hydroboost, Hyd. Clutch, Flow Cooler WP, Be Cool Aluminum Radiator, Doug Thorley, NV4500 5-Spd, NP-231D, 3.73 F/R Trac-Locs, Rustys 4" Lift, Vintage Red Metallic, Black Interior and 33X10.50X15 BFG, FiTech400 to come - IN PROCESS Bling Bling Cha-Ching
Old 02-24-2011, 09:16 PM
Originally Posted by badaboom
Emission Parts
What are some things that can happen or I can experience with this out like it is?
Year: 1983
Make: AMC/Jeep
Model: Wagoneer
Trim: Limited
• AMC 360 5.9 Liter
• 109 in. Wheelbase
Old 02-24-2011, 09:37 PM
badaboom's Avatar
Don't have a good answer for you.
Check around for the CTO valve for AMC V8
http://forums.off-road.com/jeep-shor...cto-valve.html
Interesting read
Also reference
http://www.ifsja.org/tech/fuel/pictures/8cylvac.gif
reusing intake manifold gasket matt vannucci General FSJ Tech 2 03-30-2009 05:17 PM
Heat Sink under intake manifold - where to buy? agsam94 General FSJ Tech 8 03-17-2009 05:04 PM
intake manifold removal bigbird General FSJ Tech 6 03-04-2009 01:03 AM
leaky intake manifold. Narnian General FSJ Tech 7 04-28-2001 04:51 PM
