Old 11-01-2010, 12:18 PM
JMRedwine's Avatar
JMRedwine JMRedwine is offline
Newbie!
Good afternoon Gentlemen.
I am a total newbie to the FSJ world, bought my first one this weekend.
1986 Jeep Grand Wagoneer, rebuilt AMC 360, only aftermarket is a 3.5" suspension lift and some 31" Yokohama off road tires. This thing is glorious! I was a TJ guy for a long time and loved everything about it. Had to leave the Jeep world for a while, and now I finally get to come back. I feel like I came home. I decided to go a little classier this go around, and get the Woody. So far I love it!
So a few newbie questions:
Oil-I can't seem to find it but what kind of oil does this thing take and how much? I'm guessing it holds 5q? How about transmission fluid? how much/what kind?
Next: Here's the biggie; the 4wd is currently inop. I have been told it's the 4wd solenoid and vacuum actuator. Can anyone tell me what steps I need to take to test these out, and maybe link me to some diagrams so i know what the heck I'm looking at? I'm not even sure where that solenoid is?
Thanks guys, I look forward to getting in over my head in the world of Jeep again! Sorry for my 0 knowledge base, I'm sure I'll be cruising these forums a lot trying to learn what I can! Teach me your ways FSJ dudes.
John Mark
Old 11-01-2010, 01:11 PM
argyll1984's Avatar
argyll1984 argyll1984 is offline
Welcome! I'm pretty new to FSJ's myself, I got my 79 J-10 a couple of weeks ago. I'm also a former Wrangler owner. I used to have a YJ and I just sold my CJ-7. There are a lot of very knowledgable, friendly people on here so you should be able to get most of your questions answered. First things first, what kind of tranny and t-case do you have?
1979 J-10: 360 V8/T-18A/D20/D44/D44
2000 XJ: 4.0 I6/AW4/NP231/D30/D35C
http://s1107.photobucket.com/albums/...t=fa1d077e.jpg
Old 11-01-2010, 01:26 PM
RAMBLINFSJ's Avatar
RAMBLINFSJ RAMBLINFSJ is offline
Welcome Redwine! The t-case is vacuum operated when switching from 2wd to 4wd. Then there's a shifter in the floor for High, Neutral, and Low but I'm sure you have figured that out already. There is a vacuum motor mounted on the driver side of the t-case. If you can crawl under the Jeep and watch the rod on the vacuum motor while someone else moves the switch on the dash back and forth to see if the motor is working. It doesn't move much. If it doesn't move then it's time to chase some vacuum lines. Of course, check the hoses to the motor while you are under the Jeep. Also check the vacuum ball on the firewall. Sometimes the hose will come loose there and you will lose your 4wd. I bought a super nice Wagon for cheap from a guy who thought he was having some major drivetrain problems and it turned out that the vacuum hose from the intake to the vacuum ball had fallen off.
The dipstick is on the driver side of the engine near the brake master cylinder. Oil goes in the big tube at the front of the intake. A good quality 10w30 is all need.
1984 Wagoneer
1977 Cherokee Chief (401)
1982 J-20
1965 AMC Rambler American 220
Old 11-01-2010, 01:30 PM
RAMBLINFSJ's Avatar
An '86 Model is the only year Jeep put the 228 t-case in the Wagoneers then switched back to the 229 with the viscous coupler in '87. It will also have the TorqueFlite 727 Automatic transmission.
1984 Wagoneer
1982 J-20
Old 11-01-2010, 01:33 PM
will e's Avatar
will e will e is offline
Always Broke
Welcome to the Forum. Yeah, the good news is it is probably a vacuum line that is leaking. Becareful being under the rig while it is running. if you don't see the lever moving, you can unplug the vacuum line from it and check to see if there is vacuum.
Not sure exactly how the rest of the vacuum is used on your rig but I suppose it is possible that a different vaccum line is disconnected (like maybe the one that moves the vents from heat to defrost, causing the TC line to not get any vacuum.
Old 11-01-2010, 01:35 PM
will e's Avatar
Always Broke
To avoid going under the car while it is running (always makes me nervous) you can get a little hand held pump at your local autoparts store for like, 20 bucks. Usually they have a gauge on them too so you can see if the vacuum is holding... Then you can trouble shoot where the leak is.
Old 11-01-2010, 01:42 PM
710 Burner's Avatar
All hail the noob!
The '86 could have an NP228 or NP229 if its a late '86. When you flip the switch you should hear a Psst. If you have a leak in your heat vent system it will leak the 4WD.
some of the guys use a stiffer oil than 10w30 if the oil pressure is low (usually in warmer climes)
I am not sure how much. My 87 took 6 quarts. Both my former TJ's took 6 qts. I thought all V8 Jeeps were 6 qts, but if I put 6 in my 401 it reads about a qt high.
Mark B. Jones
Old 11-01-2010, 02:25 PM
billyj7175's Avatar
Welcome from Southern Illinois...and congrats on the new Jeep!
83 J-10 Jeep "Oscar"
360/727/229
Old 11-01-2010, 05:35 PM
JMRedwine's Avatar
Thanks for all the help guys! Ok oil and transmission fluid got an overdue changing. Good to go there. Thanks!
Now pardon my ignorance...but what does this vacuum actuator look like? I stared at my T-case for about 30 minutes debating what it might be earlier! haha.
Old 11-01-2010, 05:47 PM
Smiff's Avatar
Smiff Smiff is offline
Welcome, and here is your noob initiation. Consider it like a swirlie...
Brian
86 GW, stock 360/trans "Frank"
Edelbrock carb on Offy intake
Some kind of spring lift (BJs 6 maybe)
Desert faded paint/body work courtesy AZ trails
USAF: Dropping Bombs and Hauling Grunts Since 1947
Old 11-01-2010, 09:39 PM
JMRedwine's Avatar
Well here's a pic of the Jeep from earlier today! I'd take pictures of what I suspect to be the vacuum actuator and what not...but it's currently dead in a Wal-mart parking lot! See my SOS post for details...
1986 Jeep Grand Wagoneer. Bone stock.
1999 Toyota LandCruiser. Lifted 2" BFG A/T KO
Old 11-02-2010, 07:31 AM
BoringBen BoringBen is offline
Welcome to the forum of all forums, and to the gracious living that is FSJ life. Looks like she's giving you a big hug already...
I'm a "progressing" noob myself and have found this place invaluable. The guys here are great, have answered many a dumb question from me, and the information available on these pages has done me worlds of good.
A good resource for tech stuff is oljeep.com. Take a good look around. You can find parts and pieces all over the country for our rigs, bjsoffroad.com is popular here, teamgrandwagoneer.com has lots of stuff (tends to be a little pricey), I've been able to find LOTS of stuff on rockauto.
There's a poll out here now asking what everyone uses for motor oil, 10w40 has a slight lead over 10w30. But like someone else said, climate might play into that decision.
Good luck, and hide your wallet!
Old 11-02-2010, 09:11 AM
meo954 meo954 is offline
Welcome, I too am new to the FSJ habit. This is a great website and forum, members are extremely helpful. I spent several hours reading past posts and virtually every item in the Tech Library. It has helped me diagnose and repair many items I knew were wrong with my GW and the ones I am just finding out about.
Another great resource is the Haynes Repair Manual for the Jeep Wagoneer & Pick-up 1972-1991. BJ's also has tech support by phone and email.
I have had my truck for 1 1/2months. Drove it for a week before my son decided that he would do a complete rebuild on the engine. Hope to have it back in by next weekend.
Woodley - 88 GW
BJ's 2" Lift
360 w/Edlebrock 4BBL, Man,
Cam, Headers, HEI
Old 11-02-2010, 09:15 AM
RAMBLINFSJ's Avatar
Here's what the actuator looks like off the truck.
http://www.teamgrandwagoneer.com/par...ailed/221.html
1984 Wagoneer
1982 J-20
Old 11-02-2010, 09:39 AM
24tesla's Avatar
24tesla 24tesla is offline
Is that locking hubs I see on the front wheels? I may be wrong, my eyes are not the best, but it either looks liek a bow tie, or a locking hub almost to me.... Help me out guys.... If it is, then not stock for an 86. so no telling what has been put in there. Some very knowlegable folks around the NC area, that may be able to meet up and help ID if you are runnign the stock t-case, or if another has been swapped. I wil be replacing mine with the 208 and Manual hubs here in the near future.
Kevin
86 GW, 360/727, Edelbrock 1406 w/ performer alum. intake. AGR Super PS Pump, HEI ignition upgrade. Other than that, stock for NOW!
http://gfsj.org
My Web Page
Old 11-02-2010, 10:18 AM
argyll1984's Avatar
I zoomed in on it and it looks like a locking hub to me.
Old 11-02-2010, 05:04 PM
JMRedwine's Avatar
Definitely has locking hubs. So I'm dealing with a frankenstien here?
Old 11-02-2010, 05:53 PM
EBCIII's Avatar
EBCIII EBCIII is offline
Welcome to the site! Glad to have you on, Beale.
____________________________________
"Old Yeller"
77 Wagoneer 360 Engine. Work in progress.
235/75R15 Michelin LTX M/S2
Old 11-02-2010, 06:39 PM
Smiff's Avatar
Quite possibly, just hope your p.o. made any other changes for the better and not the worse. Most people seem to experience the worse side....
That is a good looking start to a project though. Your wheels look good. I've always liked the stock wheels on these trucks (86s, that is.)
Brian
Old 11-02-2010, 10:39 PM
jdaniel83's Avatar
jdaniel83 jdaniel83 is offline
Good looking rig. I have the manual locking hubs on my '89 and love them. Of course like Smiff said hopefully the previous owner took the time to properly switch from auto-locking to manual-locking hubs or else they could have something to do with your no 4WD situation.
'89 GW; 4" Susp Lift on 32" Wild Country MTX; 360, HEI, Edelbrock Intake, Melling MTA-1 Cam, Summit 600 carb, 3.73 Gears
'70 Wagoneer; stock Buick Dauntless 350, TH400; 3.73 stock gears
'83 Wagoneer Limited; stock 360, 727, 3.31 gears.
FSJ newbie - what makes a good GW ErieBeach General FSJ Discussion 40 12-19-2009 04:05 PM
newbie question ghost rider General FSJ Tech 3 05-29-2009 10:49 PM
Newbie question Weeg General FSJ Discussion 22 05-02-2009 11:27 AM
newbie to the thread kevbosjeeperworks General FSJ Tech 3 04-15-2007 09:02 AM
Newbie Question..... Geminiroq General FSJ Tech 7 04-09-2007 06:42 PM
