Old 11-12-2009, 07:46 PM
jtr's Avatar
jtr jtr is offline
12 bolt h1 build with Pitbull Rockers
4 used 12 bolts off ebay, came with hardware and o-rings.
Cut out the centers w/ torch
1/2 rock rings from Mac
Pressed Centers
jig for measuring
16" pvc cut to 6.75" with skill saw.
Welded one in @ 3.2 backspacing.....most I could get!
Jeep is gone ~~ Ranger cab truck in the works
393W/C6/203-205, HP60, 14B, 12 bolt H1s, 40" Pitbull Rockers, full hydro, 4 link rear
Build = http://www.pirate4x4.com/forum/showthread.php?t=973973
Old 11-12-2009, 07:52 PM
jtr's Avatar
jtr jtr is offline
Close up weld
added some primer
More paint
Old 11-12-2009, 08:02 PM
jtr's Avatar
jtr jtr is offline
Welded up original rectangular hole and re-drilled for normal/common valve stem.
Took a router to the inside edge so the insert will seat, if you don't the halves will never bolt together and seal.
Just for fun..
33s
38 TSL
42 Pitbull Rocker
33s on new wheels
Got some new tires 39.5 x 16.5 x 16.5 Pittbull Rockers
Old 11-12-2009, 08:53 PM
cmelo's Avatar
cmelo cmelo is offline
Very nice combo, I've got some H1s that are waiting for me to get some DRW axle to bolt under mine. If I buy new i'm buying rockers as well. They get awesome reviews and I've seen them perform in person and they're an awesome tire.
79' J10 360/T18/D20- Locked & bobbed on 35s
Old 11-12-2009, 09:15 PM
FSJ Guy FSJ Guy is offline
That's a NICE welding job there!
Ethan Brady
www.bigscaryjeep.com
Old 11-12-2009, 09:33 PM
jtr's Avatar
jtr jtr is offline
If you attempt this project get your wheels sandblasted. Paint used by the military is tough to remove and smells terrible, it's worth the $15 per wheel to have them blasted.
Old 11-12-2009, 09:37 PM
jeepjerry's Avatar
Wow!!!....thats sweet work!!....
1977 J-20, 4bbl AMC 360/t-18,33"s.
1976 CJ-5, Healthy AMC 360/t-18, 6" lift, 35"s.
1972 Javelin SST, mild AMC 360. Under cunstruction.
AMC ya!!
Alfano Performance
Kenosha, WI 53142
Old 11-12-2009, 09:47 PM
cmelo's Avatar
I notice you have a plate on the front of your truck. Are you going to drive it on the street? I'm curious to see how well it rolls on the self welded centers. Your welds look great so if it works for you maybe when I get a bit more confident I might rethink going DRW and just recenter my H1s.
Old 11-12-2009, 10:03 PM
NVJEEPER's Avatar
NVJEEPER NVJEEPER is offline
WOW!!! NICE welding...an tire's!
Damon
'85 Grand Wagoneer
Old 11-13-2009, 06:47 AM
Casey's Avatar
Casey Casey is offline
Jeep Polygamist
1994 YJ
1986 Comanche
'57 FC-150
Carolina Full Size Jeep Club
www.cfsjc.com
www.patriotguard.org
"Go forth and be a tool".
Old 11-13-2009, 07:30 AM
orangecherokee's Avatar
good post. i love the way those rockers are looking
Old 11-13-2009, 08:04 AM
Very nice indeed!
Old 11-13-2009, 08:13 AM
jtr's Avatar
jtr jtr is offline
This truck is street driven and it rolls fine with the self welded centers. Just for the hell of it I measured the backspacing on my factory built 16x10 Steelies and they had a runout of .040" or worse. I got all of my centers < .020". Not worried about it.
Old 11-13-2009, 08:40 AM
JeepsAndGuns's Avatar
I have the exact same set of wheels and centers sitting in storage waiting for my build to get funded.
I have been wondering how I was gonna get the centers, well....centered! Seems like a pretty nifty idea, I will remember that.
Looks good!
Old 11-13-2009, 09:33 AM
toyjeep's Avatar
toyjeep toyjeep is offline
I did the same thing with 8 bolt wheels. IIRC you get 3.5" BS out of those. My home welded ones run true enough on the road as well. There is a nice lip in the wheel on 8-bolt to press it againt for trueness.
What exact router bit did you use on your PVC inners? I did something similar on one insert so far with a grinder.
What exact size pipe is it, i.e. 16" SDR 18....? The PVC I scrounged up seems to be a 1/16" too small to fit over the inner wheel on the 8-bolts. I have to persuade it on and off.
'Pepper' -- '77 Cherokee w/ 360/435/203/205/HP60/14B/42's
Old 11-13-2009, 09:42 AM
jtr's Avatar
jtr jtr is offline
Mine do not come off easliy either, it is such a tight fit that if you do not drill some holes in the PVC no air will get into the tire area.
PVC was 16" water main, I thought it was too small too but all the research I did said I had the right stuff.
The bit was a 1/2" round over like this.
http://t2.gstatic.com/images?q=tbn:m...8%26Task%3DGet
Old 11-13-2009, 09:46 AM
jtr's Avatar
jtr jtr is offline
Another note. These things are heavy.
My Jeep weighed 4940 lbs with old tires and wheels.
Now it weighs 5300.
Additional 360 lbs or 90 lbs per corner.
Old 11-13-2009, 10:04 AM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
very cool, and yep, they are SUPER heavy
BJ's Off-Road
ryan@bjsoffroad.com
Old 11-13-2009, 11:47 AM
toyjeep's Avatar
So you put a round corner on it instead of the magic 13 degrees, or whatever that number is. (can't remeber without looking it up)
Holding air well? Without my inserts I may have 1lb leak over 1 month.
Old 11-13-2009, 11:52 AM
jtr's Avatar
jtr jtr is offline
Yeah it is round, no magic 13 degress. Holding air great, found the key is getting everything clean with soapy water. I cleaned all mating surfaces with sponge and soaked the o-rings in the same bucket with warm soapy water.
