Old 05-26-2020, 01:33 PM
ZBRA ZBRA is offline
Who has done the LS swap, but used a manual transmission?
Everyone I have seen is mated to a slush box. Where are the manuals? What 4WD manual transmissions with overdrive will hold up to the torque of the LS motors?
Thanks!
Old 05-29-2020, 09:19 PM
GM NV4500 would work.
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 06-04-2020, 10:11 AM
Simo's Avatar
Simo Simo is offline
x2 on the GM NV4500 ideally. feasibly an AX-15 & NV3550 5 spds or NSG370 (6 spd) found in later model XJ/TJ jeeps could be adapted. Novak and Advance adapters cite they can hold up to V8 power but these are not heavy duty trans like the NV4500. FWIW i have an SM465 4spd behind a 5.3L LM7 in an offroad rig and while it handles the load no problem it shifts like an old dump truck.
A quick search of 'max input torque ratings' for some of these offers the following informal list for comparison:
- NV4500, 460 ftlbs
- AX15, sources suggest similar to NV3550
- NV3550, 300 ftlbs
- NSG370, 272 ftlbs
- SM465, 465 ftlbs (non synchro 4spd)
Other 4spd options NP435, SM420, T18, ...
Not sure what LS you're planning on, but a search for a run of the mill LM7 suggested they can output around 325 ftlbs peak torque stock.
Old 06-04-2020, 11:18 AM
I really appreciate all that information. I definitely don't want a non-synchronized 4spd. I was hoping for something synchronized, smooth, and with at least 5 gears. Sounds like they exist, but they will have a expiration date even behind a 5.3L. Ideally, I would prefer a 6.0L or 6.2L.
I believe the NV3550 can be found mated to the 4.8L, but I'm not going through the expense and time of this swap to only have a 4.8L.
Old 06-04-2020, 01:23 PM
Simo's Avatar
The Novak site has a helpful tech vault and they offer a bunch of adapters for different transmission options should you choose to go that route (select the 5 speed drop down to view half a dozen options here)
https://www.novak-adapt.com/knowledg...ssions/manual/
Though rare, there are some factory 6.0L NV4500 trucks out there so you wouldn't need any aftermarket adapters just the 6.0L flywheel and related donor parts.
Old 06-05-2020, 08:58 AM
Great info! Thanks again!
1979 Cherokee Auto Tranny to T18 Manual Tranny swap questions Mtnmax General FSJ Discussion 10 01-07-2020 11:41 PM
GW manual transmission swap question...HELP!!! GallionSW General FSJ Tech 1 10-19-2010 09:58 PM
Manual Trans Swap msh227 General FSJ Discussion 0 09-23-2010 10:26 AM
Kick down TH400 Bill Lawton General FSJ Tech 10 09-28-2007 10:07 PM
Manual Transmission Swap sanders General FSJ Tech 4 02-21-2001 11:49 AM
