Old 12-03-2018, 01:55 PM
Fuel lines for TBI
I am going to plumb my TBI fuel lines this week. I am using my original supply line as my return line. I have a bunch of 1/2" aluminum Moroso fuel line I can use for the supply side but think it may be a bit big? Does that matter? Should I just order some 5/16's or or other for my supply line?
Also, I have the good ol' fashioned stock 79 tank. I plan to run an inline pump so if it fails, I don't have to drop my tank to replace it. On the pickup, I planned to basically mirror the original pickup (seen below) but with a sock at the end. I plan to have the return line return the fuel over the pickup (basically remove the soft end on the current pickup you see in the picture.
Thoughts?
Old 12-06-2018, 04:17 PM
Anyone use 1/2 line?
Old 12-06-2018, 08:04 PM
1/2" too big imho...3/8" isn't even required.
If I was to do one again, I'd probably use the nylon stuff and the required efi fittings.
I've had several issues w/ metal efi clamps seems the chinese can't even get those right.
The nylon stuff would allow eliminating clamps.
I might even switch still? A roll is only like $20 and the fittings are cheap too.
Old 12-07-2018, 11:20 AM
I hadn't even considered nylon. Hmm. Thanks.
Old 12-12-2018, 06:27 PM
Tripwire's Avatar
Tripwire Tripwire is offline
I reused the carb lines already existing with no issues
Abort? Retry? Ignore? >
vapor locking JeeplessJohn General FSJ Tech 17 07-25-2017 08:11 AM
suburban DD, pulling hair out over fuel lines!! muddy General Chit-Chat 2 03-04-2016 09:12 AM
I guess it's getting hot.... Belteshazzar General FSJ Tech 3 04-22-2009 10:02 PM
How many miles should it go? 82Laredo General FSJ Tech 9 01-20-2007 10:23 AM
Upgrades/Tweaks to Improve MPG prayforsurf General FSJ Tech 33 01-04-2007 10:39 PM
