Old 07-17-2003, 03:28 AM
rockjeep44's Avatar
The Advisor
Ok, I'm hitting up the junkyards for some rear 'Burb springs so I can finish this SOA and get my shop cleaned out this weekend and ready to get my jeep torn down. My question is what all years should I keep my eyes open for, what is the length eye to eye with no weight on the spring, and will Chevy truck springs work if I can't find a 'Burb? Also, if anyone can get the eye to pin length for both sides with no weight on the spring that would be awesome. TIA
-Andrew
Buggy Buildup
Originally Posted by welchct
Old 07-17-2003, 03:52 AM
rockjeep44's Avatar
The Advisor
Ok I know I need to be looking for '93-00 burb springs so I'm good there but will '93-00 1500 truck springs work?
Buggy Buildup
Old 07-17-2003, 04:01 AM
tuck tuck is offline
I believe they will... the magic number is 63"... I'm not sure how people are getting that measurement... I'm pretty sure the truck springs will work... no idea on eye to eye without weight, sorry
1972 Wagoneer 360/th400/dana20/10b/14b/35\'s... welded diffs, full hydro and so on..
Old 07-17-2003, 04:59 AM
blt2krl's Avatar
blt2krl blt2krl is offline
You can use any half ton rear leaf pack from 88 to 98.5. This includes the 2wd versions as well. I can't give you the measurement cause mine are under the rig. You will also have to use the chevy shackle besause the jeep one is not long enough to bolt to the spring without hitting the spring.
[ July 17, 2003, 11:01 AM: Message edited by: blt2krl ]
Paul Hartman
79 waggoneer
AMC360/TH-400/203/205
www.cbioffroadfab.com
WWW.PLANET4X4.NET
Old 07-17-2003, 05:04 AM
These are 96 3/4T Burb springs laid out W/O overloads next to OEM FSJ springs... they are 2-3" longer and the spring pin is centered on the Burb springs.
With the springpin being centered... it relocates the axle 4.5" to the rear...
Sorry I don't have the EXACT measurements... but this should give you an idea
important note
Since the burp springpin is centered... the pinion angle is angle more downward.... make sure you check your angles as I needed to reangle the perch another 4.5 degrees after swapping the springs
[ July 17, 2003, 11:06 AM: Message edited by: River Beast ]
Todd
www.ttsfabworks.com
Old 07-17-2003, 05:17 AM
blt2krl's Avatar
On my half to springs, I didn't haver to change the perch angle at all. It was right on. Your 3/4 ton springs look to have more arch than my 1/2 tons, but that would make sense to me..
Paul Hartman
79 waggoneer
WWW.PLANET4X4.NET
Old 07-17-2003, 05:42 AM
rockjeep44's Avatar
The Advisor
Thanks guys. I just got back from the junkyard, I got a pair of 1500 Chevy Pickup springs, not sure what year but they are in awesome shape, complete with shackles. They have a centered pin and measure 62.5in eye to eye. They have 3 main leaves and an overload. Not sure if I'm gonna leave that in or not. Any reason why these wouldn't work?
-Andrew
Buggy Buildup
Old 07-17-2003, 07:19 AM
tomd's Avatar
tomd tomd is offline
All i know, is the 92 GMC 2wd 1500 ones i have, have one less leaf than blt2krl's, just the overload IIRC...
71 J-4000 on a 76 Cherokee chassis with homemade flatbed
360/Th400/PT QT/3.07 D44s
Old 07-17-2003, 03:10 PM
I removed the overload and still sit about 2.5" higher in the rear.... waiting on 2.5" AAL's for the front....
I could just remove another leaf from the burb packs, but I don't want to chance overstressing the springs on flex...as they flex GREAT right now.
Todd
www.ttsfabworks.com
Old 07-19-2003, 01:33 PM
orangecherokee's Avatar
RB, have you actually installed the springs yet? did you run into any problems with your kit?
Old 07-20-2003, 05:30 AM
Yeah.... springs are installed.... the only thing you need to do with my kit is swap (left to right) the rear inverted mounts to get the mounts into postion for the longer springs.... worked pretty easily....
Like this...
[ July 20, 2003, 11:31 AM: Message edited by: River Beast ]
Todd
www.ttsfabworks.com
Old 07-22-2003, 10:07 AM
Zorm's Avatar
Zorm Zorm is offline
Ok all this sounds kinda cool, but why are you all doing this. Have I missed something?
83 Cherokee 4dr WT(axles)
4" lift, 351w in the works
78 Cherokee Chief 304
07 Sea Ray 205
71 F-250 Camper Special 390
HE guides my path, forgives me when I stray and lights my life.
Old 07-22-2003, 10:11 AM
blt2krl's Avatar
I'm doing it for one reason alone. I want to fit a 14 bolt underneath my rig. The gas tank will cause some interference if the axle resides in the stock location. So the burb springs will locate the axle 3-3.5in to the rear and allow the 14 bolt to fit in. The other reason is to extend the wheelbase a bit.
Paul Hartman
79 waggoneer
WWW.PLANET4X4.NET
Old 07-22-2003, 10:20 AM
I did it for one reason.... adding rear flares BEHIND the doors....
Todd
www.ttsfabworks.com
Old 07-22-2003, 10:37 AM
KYJ10 KYJ10 is offline
Just a side note here. The 14ff works without any tank interference on the J10. Dennis
Starting to miss the addiction!
Old 07-22-2003, 10:50 AM
blt2krl's Avatar
Who cares about the trucks....LOL
Paul Hartman
79 waggoneer
WWW.PLANET4X4.NET
Old 07-22-2003, 10:52 AM
blt2krl's Avatar
get out there on those crutchs and get those flares on Marine... LOL How is the knee Todd?
Paul Hartman
79 waggoneer
WWW.PLANET4X4.NET
Old 07-22-2003, 01:59 PM
Stolen76 Stolen76 is offline
will this work without Todd's kit, or do you have to do the shackle inversion? I'd like to get my axle back further, but don't want more height. I like tire clearance by sawzall, but don't want to cut my doors off.
76 Wag, 360, TH400, 3.55\'s<br />Q-Trac P/T, 16%OD, 2\" AAL<br />Uniroyal LT265/75-16\'s on 16x7\'s
Old 07-22-2003, 02:25 PM
you can do this... but you would need to relocate the rear hangars by cutting them off the frame and moving them back.....
Paul,
Knee is coming along... off the crutches now... back in the garage for light work... kits and stuff... no heavy crap yet as I can't brend past 90 degrees yet....
thanks for asking
Todd
www.ttsfabworks.com
