Go Back   International Full Size Jeep Association > Tech Archives > Topic Of The Month
Old 02-22-2004, 03:47 PM
RustyJeep's Avatar
RustyJeep RustyJeep is offline
I have found that the hilift is a good auto body tool. I rolled my VW Sciroccoo last winter, and the roof was caved in a little too much to allow the driver's door to close. In comes the hilift...I put it in the door opening along the door sill on a block of wood to disperse the load, and jacked it up...after some creaking and groaning, my roof was relatively straight and my door closed with no problems. To this day I am still driving the VW as a DD. A poorman's port-o-power! Lets hear some other interesting uses
[ February 22, 2004, 09:49 PM: Message edited by: RustyJeep ]
-Rustyjeep-
aka Ben Mitchell
'73 J4000 3/4 ton -nothing stock-
Old 02-22-2004, 05:21 PM
Midnightwagon Midnightwagon is offline
I used it to take out a big dent on my bed rail on the truck. uhm I used it to pull a motor out of a burned R.V., the jack handle makes a great leverage tool.
my jeep has gone to that great big salvage yard in the sky
Old 02-23-2004, 08:25 AM
youngjeeper's Avatar
youngjeeper youngjeeper is offline
i herd people using it as a tie rod.....ive used it as a cheater bar to get more leverage loosing bolts
88' GW Stock & Mint
77' CJ-7
http://gfsj.org/forums
Choptop/Crew Cab Build-up
http://www.ifsja.org/forums/vb/showthread.php?t=93389
Old 02-24-2004, 08:38 AM
Millerluck's Avatar
I've used it instead of a chain fall to take a machine apart before I put it down in the basement.
There's the ol' break the bead on a tire trick too. Place bace plate on flat tire...jack up bumper till bead pops off.
Later
Larry Miller
88GW "Mississippi" 401,Edelbrock heads,and stuff,
4" Skyjacker, BFG AT's,OBA,Air Horn.
'89GW "Mutt" wood for now, 360, 1405, Edelbrock cam,
4"Rusty's,3"body,33"BFG. Detroit Truetrack Warn Hubs
The Metal Workshop
http://www.themetalworkshop.com/index.html
Old 02-24-2004, 11:01 AM
AMC258 AMC258 is offline
Seen them used to straighten bent tie rods, also seen them used as a come along.
Aaron McGuin <br /><br />80 Cherokee (The Short Bus) <br />Rebuilt 258<br />T176/NP208<br />31x10.50x15 OTR Muds from High Tec Retreading<br />84 GW (Gabby)<br />258/TF999/NP229<br />really bald 235 75R15s<br />Slowly becoming a shell of its former self.
Old 02-24-2004, 12:33 PM
mountainlander mountainlander is offline
Heard of someone retrieving a snagged roto rooter with one the other day....
Robert Fenton
Old 02-24-2004, 01:05 PM
Desert Beast's Avatar
Desert Beast Desert Beast is offline
360 AMC
i used mine to smash out the windows when i chopped my top.
heres one used as a tierod
Old 02-25-2004, 11:00 AM
Ihave used mine to pull wire when there was no room to get a tugger in
Old 02-27-2004, 10:53 AM
Fornesto Fornesto is offline
My dad told me about how when his family moved to Alaska in 1962, my grandfather used two hi-lifts to pull a travel trailer about 12' sideways out of a muddy ditch somewhere in the interior.
Old 02-28-2004, 12:05 PM
greasyjeep greasyjeep is offline
Used it as a come-a-long to pull down a dead tree.
Use the handel as a breaker bar all the time.
It also makes a great whiffel ball bat in a pinch.
Dipping the end in the grip maker or electric tape a dozen time over the course of a couple days and letting it sit for a weeks make it much nicer to use and helps quite the chatter when driving.
Josh<br /><br />1983 Cherokee Laredo <br />2000 TJ <br /><a href=\"http://www.simbur.com\" target=\"_blank\">http://www.simbur.com</a>
Old 02-28-2004, 04:14 PM
Casey's Avatar
Casey Casey is offline
Jeep Polygamist
I used to have a ratty CJ-5 that I would jack up out of the mud and such and kick it off the jack. The Jeep would move a little and ya' keep doing it until your out. I also cracked one of my teeth and jaw with one at the Y-O Ranch Jamboree. OUCH!! Be careful because they can bite.
1994 YJ
1986 Comanche
'57 FC-150
Carolina Full Size Jeep Club
www.cfsjc.com
www.patriotguard.org
"Go forth and be a tool".
