Old 07-15-2019, 01:28 PM
Full Size Jeeper's Avatar
Torque strut on transfer case install help
My Wagoneer never had one mounted when I bought it. It was in a box with a lot of other parts. Looked on my parts Wagon and it is also missing. The bag had a threaded rod, spring, two washers and a bunch of worn out bushings. I ordered new bushings from BJ's, but not 100 percent sure how it goes together. Can someone help me out with a pic or order in which it goes together. Thanks in advance. Darin.
1978 Wagoneer
Mods:
Old 07-15-2019, 07:55 PM
SJTD SJTD is offline
Check out Frank Ziebert's build thread. He's been messing with that lately.
Sic friatur crustulum
Old 07-16-2019, 08:54 PM
Once I got under the Wagon again and started looking at it, I was the one that pulled it off. I just forgot I had taken it off. I have chit everywhere. Here it is reinstalled.
1978 Wagoneer
Mods:
Old 07-16-2019, 09:11 PM
I think mine is a little different, I am pretty sure I have a rubber puck between cross member and that cross bar. There is a nut on the top and a nut underneath the cross member. I'll take some pics on Thursday when I get home... Not sure if mine is "correct" either...
Here's a pic I found. Pretty sure this is how mine is, too, generally speaking...
79 Cherokee Chief
Transfer case/ Quatra-Track question 1975chief General FSJ Tech 5 10-31-2015 10:25 PM
88 GW transfer case leak mgmann General FSJ Discussion 1 09-22-2015 11:10 PM
Install Drivetrain w/o Transfer Case Satchmo General FSJ Tech 4 08-06-2013 02:17 PM
Transfer Case cracked driving to work today vistalite General FSJ Tech 5 04-21-2005 09:54 AM
Tranny or Transfer Case Bad???-long Marshmountain General FSJ Tech 4 09-23-2003 03:30 AM
