Old 07-08-2019, 04:52 AM
Brynjminjones's Avatar
360 Strange oil pressure behaviour
It feels like I'm asking constant oil pressure questions on here, but I've got another one.
The oil pressure in my 1991 Grand Wagoneer with a newly rebuilt 360 started acting strangely yesterday.
Engine has about 1000 miles on it since rebuild and has a new oil pressure sender.
We did a ~200 mile trip in it yesterday and the pressure was great the whole way, except it was consistently about 5psi higher than usual, hitting about 60psi driving at 70mph. Before now it would sit at about 50-55psi.
I didn't think much of this.
Once we came off the highway I noticed that the pressure started to bounce all over the place, but smoothed out some if I sped up again.
Got home and did an oil and filter change. Started it up and the pressure was normal until the new oil warmed up, when it started bouncing again.
Took it for a drive, oil pressure bouncing everywhere. I floored it to see what happened and the pressure went back to normal.
It then acted completely normally for the rest of the drive.
This morning I started it up and the pressure went all the way to 80, but was making huge jumps from 40-80. As the oil warmed up the average reading slowly dropped and became more steady, but it would still go up to 70+ at highway speeds, which it has never done before.
At idle it would bounce around 30 but was very unsteady.
I'd love to think that the new, previously working sender has randomly quit, but the higher than normal pressure yesterday morning, plus the fact that the pressure went stable again for a while after driving it hard yesterday makes me think that this might be a bigger issue.
It's with a mechanic now (already booked in for other reasons), so I've asked him to verify the pressure with a mechanical gauge.
Assuming the gauge isn't at fault (I wouldn't be that lucky), where should I start?
1991 Grand Wagoneer - Hunter Green
1998 Cherokee (XJ) 4.0
1997 Grand Cherokee (ZJ) 4.0
Old 07-08-2019, 07:00 AM
SC/397's Avatar
SC/397 SC/397 is offline
Like you noted - install a mechanical gauge on it and monitor it again.
A stuck Oil Pressure Relief Valve can cause a spike but I wouldn't think that it could cause fluctuations like that unless the spring is broke or something. I have never seen a broke one so that is unlikely. It does sound like a electrical issue in the sending unit or gauge to me.
Old 07-08-2019, 01:57 PM
brielly's Avatar
brielly brielly is offline
I doubt it anything serious. Either yoyur new sender is no good, bad guage or possibly a wiring issue. Your mechanic should be able to verify the correct pressure with a mechancal guage and narrow it doen from there.
For Sale Custom built reproduction Rhino Grilles http://www.ifsja.org/forums/vb/showt...24#post1676924PM me for details or email rrielly@verizon.net
1982 Cherokee Chief 258 6 cyl, AX-15, NP208, mopar mpfi, hydroboost brakes.
1983 Jeep Cherokee Laredo 258 6cyl*SOLD*
Old 07-08-2019, 02:55 PM
Thanks both - I will make sure it gets verified with a proper gauge.
Here's a video I took immediately after starting it this morning. Ignore the pop noise as I hit the throttle - I think that must have been a coincidence as it didn't come from the engine.
You can however also hear a tick which has recently started and gets louder if I touch the throttle, although it sounds exhaust-y to me.
https://www.youtube.com/watch?v=C1c7...ature=youtu.be
Old 07-08-2019, 06:43 PM
I think these senders are grounded via the threads - so if you used teflon tape it can break the ground intermittently. Happened to me...
1984 GW
360
Comp 260H
Magnum Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
Old 07-08-2019, 09:30 PM
ZackN920's Avatar
ZackN920 ZackN920 is offline
Looking at that video, i'd say the gauge or sender is flipping out. That is just way to sporadic and doesn't look like it would really match much with the engine speed. I wouldn't think that it would vary at all if it is just sitting there idling after a start.
...not too rusty anymore
Plenty of patina
The others
1926 Dodge Brothers Business Sedan 212 I4-CRANK START
1987 Lincoln Town Car Signature Series-5.0 AOD (WD)
1987 Dodge Dakota LE 3.9, A999, 3.90 gear (DD)
1994 GMC 'Burban 5.7, 4L60E, NP241, 3.42 gear (DD)
2001 Jeep Cherokee 4.0, AW4, NP231, 3.73 (limbo)
Old 07-09-2019, 02:15 AM
Thanks, I'm waiting to get the Wagoneer back to investigate further. After dropping it off at the mechanic, we realised that the threads on the oil pan drain plug are stripped and it started spewing oil everywhere!
The strange thing with this bouncing gauge is that it still changes with oil temperature. Once it's warmed up, the range it bounces over moved much lower at idle.
The moment I sped up to highway speed it went back up to 70-80 kind of range.
Old 07-10-2019, 02:24 AM
One small update - the mechanic it's with has had the relief spring out, and said it was completely free, so it looks like that shouldn't be a problem.
If that's free, is there any other way the pressure could go this high?
It's looking more and more like the sender.
Old 07-10-2019, 09:39 AM
bad wiring/connection in circuit.
on 86-up if disconnect sender wire OP pegs on gauge.
Old 07-10-2019, 01:42 PM
Thank you - I knew that it pegged if disconnected, but the fact that this isn't simply pegging is what threw me!
Anyway, today it has started jumping around even without the engine running, so I know for sure it's the sender.
I drove it about 15 miles and at one point the gauge even started working correctly, although not for long.
I will be putting a new sender in ASAP.
I've also confirmed that my engine tick is definitely the exhaust manifold, so it's all-round a pretty good Waggy day!
Old 07-10-2019, 02:03 PM
unlikely it is the sender more likely it is a wiring issue with those symptoms.
Old 07-10-2019, 02:19 PM
I hadn't actually considered that yet! I will try grounding out the wire to see what it does.
If it goes to 0 and stays there, I assume the wiring is good?
Old 07-15-2019, 05:02 AM
Right, I've verified that the wiring is good and installed a new sender. This new (different) sender reads lower than the previous one did though!
Anyway, I finally got my mechanical gauge hooked up (temporarily) and here's what it's doing:
Cold start: 57psi
Normal driving once warm: 25-50psi
Hot idle (in Park): 20psi
Hot idle (in Drive): 15psi
All of these figures are very stable with no fluctuation. Hot readings were after about 30 minutes of driving.
Using 10w-40 oil.
Is that about what I should be seeing with a new (1k miles) rebuild?
Old 07-15-2019, 08:19 AM
SC/397's Avatar
Which weight oil are you using?
Old 07-15-2019, 02:59 PM
I'm using 10w-40 oil.
I've just been for a longer drive - about 40 minutes at varied speeds and 20 minutes at 75mph.
At 75mph, oil pressure stayed at 45psi. After the high speed stretch, idle oil pressure was about 12-13 before coming back up to 15 once the oil cooled down a touch again.
This seems a touch low for a new rebuild to me - should I be concerned?
Old 07-15-2019, 04:17 PM
SC/397's Avatar
Agreed, It is a little lower that I would like it for a new engine. Not a fix but, I would run 20w50 in the summer months and see if it stays a little higher. If it starts going lower then you might have to open it up and check clearances and detail the oil pump system. Rang-a-stang had a similar problem. He starts talking about it on page 12.
http://www.ifsja.org/forums/vb/showt...185193&page=12
Old 07-15-2019, 04:28 PM
Thanks, I'll have a read through that thread in the morning.
I was previously running 20w-50, but it really seemed like it took a long time to circulate on startup. It quiets down much quicker with 10w-40.
I should mention that the timing cover was replaced during the rebuild and we put new Melling oil pump gears in. The oil filter adapter is original and wasn't touched.
I'm not sure if any of the oil pump clearances were checked either.
I'm thinking about ordering a mid-plate - would that be a good move?
Also, my engine builder is replacing the oil pan for me in a couple of weeks due to a stripped drain plug. Is there anything worthwhile to check whilst the pan is off?
Old 07-15-2019, 05:27 PM
Those pressures are not bad, I would run it. It could be a little higher on a blueprinted motor but just an average rebuild, not bad.
Old 07-15-2019, 06:08 PM
The end clearance on gears if out of spec will lower pressure some.
Simply installing a mid plate will not change end clearance and probably do nothing for PSI.
I'd just run it and keep an eye on it.
Old 07-15-2019, 07:05 PM
SC/397's Avatar
I am not a fan of the mid plate. Just have the oil pump cover lapped to get a nice finish.
No matter who's name is on the box, there is only one oil pump kit for the AMC V8 which is the K85 Melling. No need to change that.
If he has the oil pan off make sure that he has something to replace the button on the bottom of the pick-up screen. See page 16:
http://rebsamcandjeep.proboards.com/...builds?page=16
Never use a Fram Filter. I like the B9 or B39 Baldwin or the ACDelco PF24.
lost oil pressure after 20 minute break in willysworker General FSJ Tech 20 03-17-2012 07:06 AM
360 Oil Pressure Sending Unit Location JohnIL General FSJ Tech 3 02-24-2006 03:19 PM
360 "backwards" oil pressure prob ivbeenjeeped General FSJ Tech 8 12-31-2002 12:15 AM
Q-Jet rebuild, How hard? porkchop General FSJ Tech 6 04-17-2002 03:01 PM
Strange Pressure readings Snakeyes_Tx General FSJ Tech 4 09-13-2001 12:18 AM
