Old 07-05-2019, 10:44 AM
Atlasts's Avatar
Atlasts Atlasts is offline
Removal of Emergency cable from foot pedal
I am looking for ideas on how to remove the emergency brake cable from the inside brake bracket. I removed the clip but how can I get the cable lifted enough to slide it out without damaging the cable or do I need to remove the cable under the cab?
Old 07-05-2019, 10:49 AM
you need to remove the rear brake cables from the front in able to gain enough length to remove the cable from the foot pedal.
Old 07-05-2019, 01:18 PM
Atlasts's Avatar
Thanks - I was hoping there was an easier way.
Old 07-05-2019, 02:48 PM
cut the cable!
Old 07-05-2019, 04:35 PM
Atlasts's Avatar
Lol - I loosened the nuts where it attached to rear cables and that have me enough play to get it out. (Without cutting it)
Old 07-06-2019, 09:13 AM
good.
Emergency cable for 63" spring swap Woody Long General FSJ Tech 5 04-30-2006 04:59 PM
Hood latch cable caionneach General FSJ Tech 13 11-07-2005 03:47 AM
Battery/starter cable rigging on 1989 Matthew W. Woodruff General FSJ Tech 2 03-10-2004 10:50 AM
one thing after another - throttle cable chrisfa1 General FSJ Tech 2 01-27-2004 02:45 PM
emergency brake cable shredby4 General FSJ Tech 3 06-22-2002 02:42 AM
