Old 07-03-2019, 04:33 PM
Full Size Jeeper's Avatar
Advance curve question/ MSD distributor
My main questions are, at what RPM do I want all my timing in at, and what would be a good starting point to shoot for total advance.
Right now I have 12 degrees of initial timing at idle with a total of 26 degrees all in at over 4500 rpm. The advance springs are the heavy springs that bring the timing in slow and at a high rpm. My idle is at 750 with a Holley sniper.
engine specs.
10.6 to 1 compression
523 lift cam
273 duration
2200 stall converter
Edelbrock heads
Edelbrock Air Gap w/ 1 1/2 inch spacer.
It seems kind of sluggish, so I think it needs more timing and maybe it should come in earlier.
1978 Wagoneer
Mods:
Old 07-03-2019, 05:32 PM
26 total is low for what you have, what gears and tire size do you have?
Old 07-03-2019, 06:54 PM
31 inch tall tires and stock gears. Not sure on gears, I thought someone said, a lot of these came with 2.54, but really have no idea. I guess I need to check and see what it has. No visible tags on my axles. It will get a re-gear one day, I was thinking 3.73, that will be after it is on the road.
1978 Wagoneer
Mods:
Old 07-03-2019, 07:49 PM
Mikel's Avatar
Mikel Mikel is online now
You need to be at 32-34 deg total advance at 2500RPM, with the vac advance disconnected.
1969 M715 6x6
1963 J300 Swivel frame
Old 07-03-2019, 08:04 PM
Do I want all in at 2500 because of the converter or is it for some other reason/reasons.
1978 Wagoneer
Mods:
Old 07-04-2019, 04:42 AM
Mikel's Avatar
You may want to try different spring combinations and see what works best for you.
1969 M715 6x6
Old 07-04-2019, 07:00 AM
yes, you could try and find an old hot rod shop with a distributer machine and dial it in. you really need to find what gears you have, 3.73 would be a good all around daily driver set.
Old 07-05-2019, 10:33 AM
recalibrate the distributor msd has charts you can download that will help you get it in ballpark.
sounds like it is configured for wot on mechanical(like lighter car on 1/4 mile)advance and too large bushing preventing more advance?
with only 26* you are throwing a lot of power away.
Old 07-05-2019, 03:41 PM
Thanks for all the responses. Yes, according to what I have read and info from MSD, The total advance is coming in way to late. 2,400/3,000 rpm is where I think it should be. Also initial timing should be higher than 12. I'am getting an exhaust system put on next week. I'am going to wait until that is done. It's just to noisy. If I made any changes, not sure if I could here it ping or not.
1978 Wagoneer
Mods:
Old 07-11-2019, 07:13 AM
Tried to edit a post and lost the whole thing. Went ahead and put in the lighter advance springs in the distributor, and adjusted the total advance to 34 degrees. I was kind of disappointed the first time I ran it up the driveway, but the timing was way off. With the lighter springs and the total advance at 34, it was like turning on a light switch. Thing will spin the tires from a roll. Very happy with the way it is running. Also did A little research and if the axles are correct to the Wagon, it should have 3.54 gears in the diffs. Think I will leave that gear in the car. Used one of those calculators online and with the gears and tires I have, at 3,000 rpm's, I should be at 65 mph.
1978 Wagoneer
Mods:
Old 07-11-2019, 10:22 AM
Mikel's Avatar
1969 M715 6x6
Buick 350 overheating solved? 1969Wagon General FSJ Tech 17 03-27-2017 10:24 AM
distributor vacuum advance test will e General FSJ Tech 4 05-23-2013 06:23 AM
distributor gear swap question SVO42 General FSJ Tech 2 03-31-2010 05:22 AM
Is stock 89 distributor vacuum advance adjustable ? GED General FSJ Tech 2 01-09-2005 12:48 PM
