Old 06-30-2019, 01:14 PM
Willy D's Avatar
Willy D Willy D is offline
Carb issues
Hey all, got an '88 GW with an '86 360 in it. Been having an issue when I go over even mildly uneven terrain (RR tracks, etc) at say 20mph and up, with the engine shutting off. If I leave it sit for 20 minutes or so, it'll fire right back up and down the road we go. I have rebuilt the Motorcraft 2100 a couple years ago and haven't had issues until recently. Found the fuel pump leaking (mechanical) and replaced it. Ran over an area where they were burying waterlines in town, and covered in dirt and the critter quit, wouldn't start again for about a half hour. It's like it's getting an air bubble that has to work itself out. Any ideas?
Old 06-30-2019, 02:23 PM
redwoody redwoody is offline
vapor locking. Put electric pump near tank and have no issue since. make sure u have filter with two lines going to carb and other return to tank
88 GW hei E-fuel pump 360
Old 06-30-2019, 03:21 PM
First suspect would be vapor lock. 2nd would be ign module going south.
Old 07-01-2019, 08:38 AM
acct21's Avatar
acct21 acct21 is offline
My understanding of vapor lock does not include a mechanical ("hitting a bump") component. How does that work?
From watching the boards for a few years, I have been under the impression that periods of running well, mixed with periods of suddenly dying and not restarting (as opposed to hard restarts/hot starts, etc) were a lot of the time related to a stock ICM going bad.
Old 07-01-2019, 01:08 PM
nograin's Avatar
nograin nograin is offline
Lots of ideas.
But what I would so is try to isolate why it won't run.
Get one of those see through in-line spark testers. Then you'll know if its ignition related.
If it is, look for loose wires first. I've had the terminals in the Ford coil connector loosen up.
Check timing at idle - check idle speed solenoid is working. (saying this 'cause you mentioned it happens at crawling speed.
Check the carb - I was cleaning out my carb every few years and then a couple times a year until I figured out where the 'dirt' was coming from.
Fuel level too low or too high can also cause a stall out. Use your nose and check the spark plugs for clues.
Vapor - shouldn't be an issue - but make sure the vapor return line on th e filter is at the 12 oclock position.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 07-03-2019, 07:32 AM
Willy D's Avatar
Thanks for the input, guys. I'll start my quest. Lol
Old 07-07-2019, 11:48 AM
67GMC's Avatar
67GMC 67GMC is offline
I would suspect the ignition module if it was me. Especially if it shut down like you turned the key off. A carb issue would be felt more like loss of power, rough running. If it shut off in a second after hitting bump (RR Track), there's no way it was the fuel in my opinion since the bowl has fuel in it to last a few seconds even if you shut the fuel off at the pump. Try re-doing the some of the grounds as well. I carry a spare module with me. They're pretty cheap.
My Stable:
1984 Jeep Grand Wagoneer, 5.9L, 4x4, Auto (newest project)
1997 Volkswagen Cabrio, 2.0L, Manual
2005 Kia Sportage, 2.7L, Auto
2006 Toyota Sienna, 3.3L, Auto
2018 Toyota RAV4, 2.5L, Auto
Recent projects (no longer with us)
1987 Jeep Cherokee Laredo, 4.0L, 4X4, Auto
1967 GMC 910, 283V8, 4SPD (RIP)
Carb issues? nw_upstart General FSJ Tech 14 12-08-2007 11:24 AM
1983 Jeep Carb Issues Boghog1 General FSJ Tech 6 06-23-2007 06:19 PM
Cold Weather Starting (Carb Issues) Joe@DIA General FSJ Tech 8 10-11-2005 07:11 AM
Carb issues! If I can't fix it the Jeep's UP FOR SALE Georgia Mike General FSJ Tech 22 11-11-2003 04:49 PM
Rebuilt carb ----> Gas leak! (UPDATE) jode General FSJ Tech 15 11-25-2002 05:10 PM
