Old 05-24-2019, 12:15 PM
EasTXJEEPER EasTXJEEPER is offline
Need a good 727
My second owner 83 Cherokee Laredo just rolled over 1016 thousand on the original(?) 360, 727. with Selectrac;
The transmission is pretty tired and prone to slippage. Should I rebuild the original or just do a good working complete transmission swap?
How much can I do a overhaul for compared to a good used 727, If I can find one close to Longview Texas?
Will any 727 bolt right into my Cherokee? Thanks in Advance
Old 05-31-2019, 04:55 PM
Nope, has to be an AMC bell housing 727.
You can overhaul yourself; it's not that hard and relatively cheap (probably cost about $400) but can take some time and patience.
You also might consider doing an AW4 swap. There are several folks on here that have done it and it gives you a strong 4 speed auto. I think transfer case wise is easy, too.
79 Cherokee Chief
Had a good day at the junk yard Crankyolman General FSJ Discussion 5 04-09-2019 02:09 PM
SOS: 727 install a no go. calling all gurus. slackin' General FSJ Tech 15 02-20-2009 11:07 AM
Good Clutch Kits? Chris P. General FSJ Tech 1 10-13-2008 07:17 AM
TF 727 questions 1977Waggy General FSJ Tech 11 05-01-2008 09:00 AM
whats good o/d trans replacmt 1989 727 drives mopars General FSJ Tech 6 11-13-2004 12:54 PM
