Old 05-16-2019, 04:51 PM
JDD JDD is offline
Wagoneer mechanic on Long Island, NY?
Anyone know a mechanic that knows their way around a Wagoneer in NY area? Been having an issue with my distributor. Keeps chewing up the gear. Not sure if it timing cover related or mismatched gears, but would like someone that knows about these issues to get it together right. Motor was rebuilt a couple years ago, but gear only lasted a few hundred miles. Had the same issue before motor was rebuilt. Guessing that it needs matched gears, but would like someone to go through and get it perfect. Any idea appreciated!
Old 05-20-2019, 07:38 AM
TLCAutoTruck TLCAutoTruck is offline
Long Island Mechanic
Hello -
Our company is TLC Auto & Truck Center, Inc in Farmingdale NY. We actually have a Wagoneer here now that we are starting a restoration on.
We are more than capable to help you with your Wagoneer. We work on old, new, carburetor to fuel injection.
My email is joe@tlcautotruck.com. Our number is 631-753-2211.
Thanks,
Joe
Old 05-20-2019, 01:11 PM
Can be several things.
Misaligned (missing locator dowels) oem cover?
Poor quality aftermarket timing cover?
Poor quality aftermarket HEI distributor?
Poor quality timing sprocket? (Oil slot wrong location)
Need more info...
What was done when engine was rebuilt/what parts were used?
Old 05-20-2019, 06:36 PM
letank's Avatar
letank letank is offline
the timing slot misalignement can be a reason, make sure that the slots match on both parts, otherwise time to use a grinder or a file to make your slot
http://theamcforum.com/forum/topic67102&OB=DESC.html
better or more picts here
http://www.fsjnetwork.com/forum/view...12192&start=20
or , not too obvious but a dowel is in the camshaft end and it matches the oil hole in the timing gear
Michel
Old 05-21-2019, 04:25 PM
JDD JDD is offline
I am guessing it may be the timing cover. Motor was rebuilt, but the timing cover was not switched out. Had the same issue before rebuild. There seems to be a slight movement from side to side when distributor is almost in all the way. After driving every so often, I would have to nudge the distributor back to correct timing, even though it was tightened down as far as possible. Not sure if cover is original? Buying one from a parts Wagoneer to replace, also getting matched set of gears for cam and dizzy. Will need to redo some wiring, but hopefully this will solve the issue. Talked to a couple local mechanics, just waiting for someone to have the time to get started.
Old 05-22-2019, 08:22 AM
What type/kind of distributor?
Grand Wagoneer Mechanic CaliSwag General FSJ Tech 0 03-15-2019 11:23 PM
1983 Wagoneer Build Kansas_Nova General FSJ Tech 69 12-24-2015 06:09 PM
So the Wagoneer has been sitting a LONG time... the original Honcho General FSJ Discussion 6 05-24-2012 06:39 PM
Grand Wagoneer, Tractor......... Am I nuts? (kinda long) Tyork_tex1984 General FSJ Tech 15 04-16-2009 05:14 PM
