Old 10-16-2018, 01:27 AM
ls3waggy ls3waggy is offline
"Beauty Cover" for the steering column
Hey guys, I have an 80 Wagoneer.
The plastic beauty cover disintegrated in the Arizona heat, do the 60's FSJ's have a nicer looking ring that sits around the column where it meets the dash? Something metallic?
I've googled a few times but with mixed results.
Old 10-16-2018, 08:20 AM
60's steering column and dash opening are too small compared to 80's.
Old 10-16-2018, 02:58 PM
Kinda what I figured.
Oh wail
Old 10-16-2018, 05:35 PM
Wouldn't be terribly hard to roll your own bezel.
If you have the patience for that sort of thing.
Our local library has a very nice 3d printer now.
That could be an option for you, I hear it's fairly common now days.
Steering column length? fadec General FSJ Tech 0 06-16-2018 02:05 PM
Automatic Steering column/ Manual steering column compatibility posulli88 General FSJ Tech 2 02-04-2018 12:27 PM
Replace lower steering column bearing w/o removing column? posulli88 General FSJ Tech 2 02-03-2018 06:41 AM
Steering Column Compatibility Jacksons Hole General FSJ Tech 0 03-13-2011 10:16 AM
Steering column swap & disassembly M1Garandfan General FSJ Tech 3 10-27-2002 01:45 PM
