Old 09-11-2018, 06:56 AM
FlashGordon's Avatar
FlashGordon FlashGordon is offline
vaccum diagram (printer's copy)
I needed a new vacuum diagram for my '85 GW.
I found none that I could use on the internet that I could copy so I did a new one myself. If you should need this master layout (to print it yourself) I will be happy to email you this as PDF-style
https://photos.app.goo.gl/cR6TXEXPsQvfKxEGA
https://photos.app.goo.gl/RqU1aGiqc5LtyqiA6
https://lh3.googleusercontent.com/K7oDvbZR6HAJEXYLWdNZUS-FypgQaXZOQImb2rdmnU1r5cNRt4jU28Z7XUqYKdQpFAMR1Wrrb Vs8-bKjAGfojD9gEC34n7UwKZSRAfvdZjTE4GJPdjjCIuL_CQ3FS0W S1ndfWX7OuX3NizNtk_NfCLe_QHButrDbCJ93xhBAYPwxdWz0c L6H57TCCkiCtuLRA8bHHvjDRQB9RV-WIVninEe64Oi_aP_TXSBxx9oHYZENzHYOGOuValhFg_FEmIZ2e wRgYEaTkbEJ8W0m6673kRnjgWpgrzwwix2zuBzoGgXq0yyNhsV 4S4B1He3dYTlM_GX5MdVD84H4usun0zUkUHISoW1N8AICo0tnN _7PZrqb1oAY8cjp5d9vbi18FHP0nF7mY2VRTkstWu09lCzbSJt aVrJMoue1-Xpfd7FEhePh5nvLysiNmZa3zNwkycsCoO29vo1eYb591rXHRjF 58lf4kFEx9YiNf-PY0v_piaKk1TXBnqpE-FNbQiEj7VWqPdLzZUP1y-XkUBeCIwVP6o7xMASwFn9KPotSEaaKjX3Q3E8uQObAcf1_5YNc lToTLhad1AKH9Aq14ccL6rOScc102cYhukzaD16puTLRsFhIui a38JjTcX_hAINFZDUmyCWzRf20ppWhlAEE4lcdu5k6IZ-9QOZBNTQ4cuQydMFMCGB2m8J8VthE=w1274-h955-no
https://lh3.googleusercontent.com/iYfIcUlHFnsgGWQbbTn9AjnhkVCTn0eRnZ5LsgXHJPe84lPPbB E_Xu8dgM9QiuYxSB5CJnX_OMQqseVsU_eqtjbHiY-mPAkkslm8XEW28hjF1Msi7hcQssIC-LXUCQPc3TndTfI0_aI0bFOzqnM-r_nGEstxsk5HY7oeRKi4ujjJw7hOFmOtBQDlcI48Mdt4bS9jHB Nn4xDDs3lzp_uXjPDGx08yIVxOu7Dp0KT3Unig_U2D8ktmlZAs CnFUVwQze6VFK20At6-_wg_WGwF0BovGTHQKGecbwf51TFSsMtSXF7VB1F2By7my8vGVr 7DcECGupgKTq_hpJt5N3CZfaDsIuFg28tlKQoyiOJwYMMuFme0 -lByEwra3UMb0m9w_RcT6frPwwf-0R5ZvoJcrJyTVxtzdj6EgwFg8zKFft4uh0EitdNp1R7hnekBAA n9BjBum8pFro4znpLRZS8kzGuPiouGFIjt94ta8XWIhTxpqCvR kpV4R_bZnME3atxk7ucSIwjZCHvWyQg7tKnthNUJT-m7nMaYycF-CvKbg4AD2JJn8oNbcskZ8S7F8bvQ2XVI8b5nqNgOjhiXZ-BpKZqhQK9rwePIgnEAnxa_o4FYYSOa-3LYseaCZlrFSdrIRXR7zw96MS4micU7UK0t5eSg6ZEiZKUQ6Ym BuPbzkKMeEReSDFQ6HeOWU=w1325-h955-no
https://lh3.googleusercontent.com/DZVjHmiYRUMai7LZw8R7DA4fHCxml4br1paAUI-DvoXh66EvnapWUYYX8t7dGv3WA2jtED2CslgDOxmFDioN3w224 l-rLC51VChDPwj7AcJSFKu_NJo81HYU9O3OocJk1NS1eZgnvI1zf Uzszs1n_9hnxhmx4NVuJC-y9mVVZZ3zcKkQgoAFfOhOjObQAvge7Mra5Iu6iwyEL0p5vqG4R id8jCyj5GYPK7aqgPRRdu8XULQWnVYJV9pREN06uiztaNoLlPL JtUyX4b9-Z23fIuJF2XarK4UX5CWMLhQ-mrYogiwg4kKOsSsP5NBz1kiPbtLbhFEEU0Luuh9fE0GM_AKbDw GssNDp365F1yFVObdloqpr3cA9Zsn2yik6R1TVDxH0VuHJzWvp Laxtd8KKbo9dy2cmADyhidiLx0ejEse9uNrjyFebM8_gEVQie3 qcXCmy0JVvyipaAwqz_Wv_aLPUCe_53aI3OODzz5WIEZ4pchJE fMBhPyu2Hrix40upwxN3J85HkBFP303anLCNVVx6oQtaMFUpRK aOYABsqxwfGWJ1AS3tDfo523TAEaRXpLNTUXv8tMdokun6cuaT ikii3MqMLLBYWWXKuwACFMGt9w2KECHhv4CFu4jFcIh_LnyXrv 7dlr4aYvaE7IwnQi31H3Y6pJGGGxOwkAWKyLvePat6MhUKUGfJ =w1274-h955-no
Old 09-11-2018, 01:26 PM
Probesport's Avatar
Probesport Probesport is offline
Very nice, I would love to duplicate all of the decals as well when I go to repaint.
Great work and thanks for posting.
Ken S.
Megasquirt EFI
: Heated Seats : Blower fix : Driving light brackets : Shorty headers : Coil Packs : Electric Fans
Old 09-12-2018, 03:44 PM
vacuum diagram
. . thanks
. . PM sent
. . Gunnar
Old 12-10-2018, 04:41 PM
dan01ster's Avatar
dan01ster dan01ster is offline
Vac line routing
Hi Gunnar...
I noticed your excellent reproduction of the 'vac. line routing decal' for under hood. Do you still have the PDF file available and if so could that be forwarded to me? I can use 'DropBox' depending on how large the file is. PM me when you have a chance. Thanks.
Dan in Canada.
'82 J20, 360,TF727, NP 208, Holly Projection.'74 paint scheme
'67 Jeepster 8701,true convertible,TH400,pwr top,
Buick 225.
'91 XJ, 4.0L,auto,Selectrac,Ramsey 8000,GC upcountry susp
'98 XJ, 4.0L,auto, Selectrac, police package
Old 01-01-2019, 01:40 PM
Hi Dan,
sure, no problem.
could you PM me your email-adress?
Happy New Year
Gunnar
Old 01-03-2019, 02:25 PM
Haleyville Haleyville is offline
Gunnar:
Is this diagram the same for a 1988 GW?
Thanks,
Mike
Old 01-07-2019, 05:04 AM
Originally Posted by Haleyville
Gunnar:
Thanks,
Mike
Hello Mike,
1985: spark plug gap is listed as .033-.038
1988: spark plug gap is listed as .035 in. (0,9mm)
and a detail around the check valve looks slightly different.
You can see the original 1988 print on Tom "OLJEEP" Collins' great website:
http://oljeep.com/gw/vac/88vacuum.jpg
Gunnar
Still looking for a '87 GW vac diagram........ Maryland Rick General FSJ Tech 7 07-22-2009 01:15 PM
Front D44 vacuum to mechanical Slick Willie General FSJ Tech 17 11-30-2006 02:05 PM
Need some pics of vaccum lines 87Wagon General FSJ Tech 4 08-30-2006 08:00 AM
vaccum diagram needed for I6 258 cid 1981CJ5 General FSJ Tech 2 08-27-2003 03:13 AM
Vaccum Diagram for 91 GW 91 TANK General FSJ Tech 5 08-03-2003 03:25 PM
