Old 02-24-2018, 10:21 AM
Full Size Jeeper's Avatar
If you can post pics of the frame repair at some point, I would like to see, thanks.
1978 Wagoneer
Mods:
Old 02-25-2018, 05:43 PM
Stuartbowen Stuartbowen is offline
Will do man. It will take a little bit. I coach high school track, and track season is in full swing.
Old 03-18-2018, 11:45 AM
Frame has been welded. I also cleaned up the welds a little with some Evercoat Tiger Hair. It is a long strand fiberglass resin and I really liked it. For a first timer, I felt it really easy to use. Here are some pics. I am gonna try to sandblast a little in the next coming weeks and get the underneath done for good.
Old 03-19-2018, 08:07 PM
bwwhaler's Avatar
bwwhaler bwwhaler is offline
Looks like you have a CS144 to me.. for alternator.
87 GW 360 performer intake Holley 670 HEI
Razor Grill 4"BJ's springs 32's CS-144 Serehill's light and tailgate harness
Old 07-04-2018, 09:24 AM
So, I am gonna do a fuel tank swap. I just can't see putting a tank back in that we know will cause frame issues. I am going with either the ford or blazer rear tank. As I plan on going carb'd still, I am thinking all that I need to do is keep the original mechanical pump, rehose the new tank, and find a sending unit/modify one to work with the new tank. Does this sound right? There is no need for an external pump is there?
Old 06-13-2019, 07:07 PM
After moving and remodeling a house, I am back in action again. I finally got to work on the jeep today for the first time since the move and I found out that some of my parts are missing. I am specifically looking for the levers and related parts for a left rear drum brake. I have drums and shoes and springs, just nothing else. I did not find an easy source for them, so maybe someone on here has some left over from a disc swap.
Old 06-14-2019, 06:34 AM
miracleed's Avatar
miracleed miracleed is offline
Welcome back! I'm sure someone has a box in the back of their garage with the parts you need (Unfortunately just not me). Great thread and I am amazed at the before and after on the frame!
'79 Wagoneer Limited
Old 06-14-2019, 01:49 PM
Check this thread out, too. Some good info that may help.
http://www.ifsja.org/forums/vb/showthread.php?t=187246
79 Cherokee Chief
Old 06-14-2019, 03:46 PM
thanks. will mine being an amc 20 rear matter?
Old 06-14-2019, 04:46 PM
Oh! Hahah! Yeah. brain fart. Pretty sure they are completely different.
79 Cherokee Chief
Old 04-09-2020, 05:39 AM
It has certainly been a while. I have been up to a million other things, and with my fire (my storage shed burned due to a bale of hay catching fire) I lost motivation completely. I currently am in a state of just trying to get it back together. However, I am missing some stuff. I had all of my fasteners labeled in clear plastic tackle boxes, but unfortunately those boxes were in the shed, and I am trying to regather some stuff. Does anyone know what nut is used to clamp the brake master cylinder to the vacuum housing?
TFI Swap....WOW! GI-John General FSJ Tech 48 09-06-2006 11:07 PM
Should I Go TFI from Build Your 4X4 Lyman DeKoquonut General FSJ Tech 14 12-13-2004 07:46 AM
TFI Conversion Slightly Simplified Rande General FSJ Tech 4 10-31-2003 01:33 AM
TFI & MSD Coils nograin General FSJ Tech 8 02-18-2001 06:44 AM
