Old 02-19-2015, 12:21 PM
Tbeach's Avatar
Tbeach Tbeach is offline
installing rear wiper arm on 91 GW
Need help installing rear wiper arm. See attached pics. Purchased new rear wiper arm from TGW. There are no threads on the inside of the hole in the arm. What am I missing? Is the rear wiper motor not OEM?
Thanks for your help.https://www.dropbox.com/s/k8f6le8e5a...07%29.jpg?dl=0
https://www.dropbox.com/s/ts9gok29ls...80%29.jpg?dl=0
91 GW, rebuilt and mild upgrade AMC 360, Howell EFI, 4" lift, HEI, 31" BFG AT KO2.
Old 02-19-2015, 12:37 PM
Flip the cover up on the rear wiper arm.
Install new arm on shaft.
Install retaining nut on shaft, and tighten VERY carefully.
Flip the cover down on the rear wiper arm.
Old 02-20-2015, 08:22 AM
acct21's Avatar
acct21 acct21 is offline
Carefully dribble some PB Blaster on that big mounting but in the first pic. Do that monthly forever -- so if/when the day comes you have to remove the motor, it won't snap the threaded portion off the motor case.
Old 02-20-2015, 12:16 PM
Tbeach's Avatar
thanks for the input. Will work on it this weekend.
Need picture of installed rear wiper nozzle ajminla General FSJ Tech 5 10-20-2013 02:02 PM
Rear windshield wiper fuse location? jcountryman General FSJ Tech 2 09-23-2013 09:13 PM
rear window wiper Coop15 General FSJ Tech 3 04-30-2005 04:45 AM
Need to get rear wiper motor out...how easy? jeepthing General FSJ Tech 3 09-12-2003 08:52 AM
90 GW Rear Wiper Motor Repair 90Woody General FSJ Tech 2 09-28-2001 11:53 AM
