Old 11-20-2014, 02:57 PM
DieselSJ's Avatar
DieselSJ DieselSJ is offline
Originally Posted by thechier86
10-4. I was planning on a TH400, but didn't know what t case to use for driver drop, maybe a Ferd 208? Or maybe the stock 229, if it'll bolt up. I wasn't planning on much power, so I thought it would hold up if I could use it.
If this is going to be street driven, seriously consider some type of overdrive transmission. For tcase, look at a 241 from a GM/Chevy and put it all together with factory GM parts and forget about aftermarket adapters for the stock tcase.
-99 XJ Limited.
Old 11-20-2014, 05:50 PM
thechier86's Avatar
thechier86 thechier86 is offline
Yeah, that sounds like the best way to go, really. I'm a little intimidated by the wiring to get an overdrive trans to work, but I wouldn't be opposed to a manual trans if it happened to come along. I haven't bought anything but the jeep yet, so I'm still in the infancy of the project. I'm following this build to see where it ends up, as well as considering other drivetrain that might be cheaper and or easier to make work. I just know I want a dependable fsj, and I'm not rich.
buckle up, i wanna try somethin...
Old 11-20-2014, 09:26 PM
DieselSJ's Avatar
A 700R4 is a single wire for the TC lockup. It is super easy.
-99 XJ Limited.
Old 11-21-2014, 11:32 PM
Kreter Kreter is offline
If you use something newer like a 4l80e, a aftermarket controller is idiot proof I hear. That is the route I plan on taking.
As for the motor mounts, it looks like I'm gonna start tearing back into the truck the weekend after Thanksgiving. I want to do my best to do a bolt on mount, but worst comes to worse, they may end up like the LS series YJ mounts from Novak. The directions state how far from the front crossmember to weld the mounts. I welded mine in fully and never test fit the engine once, a leap of faith I know, but when i dropped the 5.3 in, it was perfect.
Old 11-27-2014, 11:14 AM
thechier86's Avatar
That sounds great! I can't wait to see how your mounts turn out! I bought my 1 ton 6.2 stuff, I just need to pick it up. This is going to be the coolest vehicle I've built so far...
Old 12-10-2014, 07:47 PM
thechier86's Avatar
Any progress on this? I won't be able to start on mine until after Christmas...
Old 08-17-2016, 09:29 AM
Ronaldwag Ronaldwag is offline
Noob!
J10 Chevy 6 2 Swap
Hey chvlfrk, I thought you were THE chevy guy. A 302 was a 327 with a 283 crank, in 67 it was exactly that. In 68 and 69 they had their own blocks and cranks. A 283 with a 327 crank is a 307.
Chevy didnt make powerglides in 76 and it is a very unlikely swap. Most likley a th350.
th350 pan is square with a dog earred corner. th400 is shaped like the state of texas, streached a little from top to bottom.
Ill give you any help you need as long as it not concerning defiling a Ford.
Read more
Chevy Fan Swap Dumpy General FSJ Discussion 4 10-17-2012 01:09 PM
easy Chevy Gen I / II engine swap idea ??? grimgaunt Off-Road FSJ Tech 0 04-27-2012 09:45 AM
Transmission Linkage Not Fitting After Chevy Swap Rompn General FSJ Tech 1 08-18-2009 03:20 PM
Doing a chevy 350 swap. crow223 General FSJ Tech 2 09-10-2007 12:22 AM
Opinions needed for a Chevy Swap??? keej General FSJ Tech 14 03-17-2005 11:25 AM
