Old 03-24-2010, 11:57 AM
twmattox twmattox is offline
88 Grand Wagoneer fuel tank size
So, I was driving yesterday and started to lose power. If I let it idle...she would still move...but any gas at all and she would fall flat on her face. Looked at the gas gauge and it was just under 1/4 tank (and my gauge is not accurate...reading 3/4 tank at full). I knew this was the furthest I had driven on a tank of gas...but not by a lot.
So, I quickly found a gas station and filled up. Sure enough...add fuel and all is happy again. What surprised me was it only took 11.5 gallons. I know it was full, cause I could hear the gurgling in the tank fill and vent lines.
So, apparently, I do not have the stock tank? I only have a 12 gallon one??? What else could cause this? New fuel filter, new fuel pump, all new fuel lines.
Old 03-24-2010, 12:18 PM
20.3 gal. Good chance the fuel sock/filter fell or rotted off the pickup tube in turn shortening the pick up so's you can get the last few gallons out. The PU tube is part of the sending unit plate. I'd pull it it out and look at it.
Old 03-24-2010, 12:20 PM
addicted's Avatar
addicted addicted is offline
Big Meanie
They hold about 22 gal. When I bought my '89 I couldn't let it get below 1/4 tank or it would run out and it was the pick-up strainer that was at fault. I would bet the strainer sock on the end of the pick up tube is either torn or has fallen off.
Apparently I type really slow.
Originally posted by Ristow
i bet it was Simon....
Old 03-24-2010, 12:44 PM
FSJ Guy FSJ Guy is offline
Exactly. The fuel sender is located below an access plate which is under the rear seat on the driver's side.
Ethan Brady
www.bigscaryjeep.com
Old 03-24-2010, 02:30 PM
Well, I have a replacement sending unit...and now have a reason to replace it...
Old 03-24-2010, 03:46 PM
It's always nice when you have the spare parts for a repair!
Ethan Brady
Old 03-25-2010, 11:21 AM
Yes it is. Unfortunately, I have a habit of hording parts I will need for future work...then I rarely have the time to get the work done. Found neighborhood kids playing in the garage the other day...and all my parts and stuff are scattered everywhere. Not even sure what goes where now...
Old 03-26-2010, 05:49 PM
91G-Dub's Avatar
91G-Dub 91G-Dub is offline
I know for sure my 1991GW will hold over 19.7 gals.
Pumped that into it one day after driving it to the ga$ station.
91G-Dub = Bill Houston
1979/1980 J-10 Junkyard Dog 258 4 speed D44 front AMC 20 rear 3.31 Lincoln Locker Status Running
1991 Grand Wagoneer Gray Ghost (bone stock) STATUS Gone but not forgotten
"The tree of liberty must be refreshed from time to time, with the blood of patriots and tyrants.
It is its natural manure."
Thomas Jefferson
bringing back the FI fuel tank ideas... AlsChopShop General FSJ Tech 12 09-19-2007 12:12 AM
Fixed the gas tank - now the fuel gauge is DOA... dlowrance General FSJ Tech 1 09-02-2007 09:39 PM
Fuel Tank Replacement billw General FSJ Tech 2 06-11-2006 09:28 AM
Plastic gas tank 1981 J20 ? Ferrets General FSJ Tech 9 04-14-2004 02:51 AM
Help / Vapor Lock Issue key General FSJ Tech 9 04-09-2004 10:54 AM
