Old 03-21-2010, 12:18 PM
BlacksheepGW's Avatar
BlacksheepGW BlacksheepGW is offline
Dizzy gear, HEI, Cam gear, oil pump, questions.,. AHHHHh!#@$
I've searched, and read up and I know I'm suppose to use the old dizzy gear when swapping dizzies. I'm going from stock to HEI. However, my old dizzy gear is missing parts to 2 teeth. Oh yeah, and the new gear is drilled JUST above the old gear, so it cannot cleanly be swapped, but I am afraid if I cross drill the new HEI dizzy, I'll weaken the shaft and have it snap off under load.
I've read that I should "simply" swap in a new cam gear and dizzy gear (matching set), but uh.. the cam gear is buried and its not a project my back wants to work on.
I've also read that problems with the two gears can affect the oil pump, that could explain some pressure issues I've seen after driving for a few miles.
So now, if the oil pump needs to be replaced, as well as the cam gear, I might as well do the cam itself and thats more $$, plus wanting to go FI eventually, I might as well swap in a chevy SB.
Any advice will be well received and pondered.
Thanks in advance
- B
1984 Grand Waggy
AMC 360
TF727
Soon to be NP208
31"s via BFH and Sawzall
Old 03-21-2010, 12:37 PM
Fiodh. Argus's Avatar
Fiodh. Argus Fiodh. Argus is offline
well you could always gamble and just stick the new distributor and gear in there. I did that and the gear lasted fine. Other people have too. However, there's always the chance...
but to do it right, you are going to have to open it up. I would probably risk it... then eventually open it up when it does go bad and replace the gears like you were supposed to...
or you might get away with it!
Drew
77 Cherokee WT
Old 03-21-2010, 02:43 PM
So just cake it in assembly lube? I'll try that then. Thanks!
1984 Grand Waggy
AMC 360
TF727
Soon to be NP208
Old 03-21-2010, 05:15 PM
sld's Avatar
sld sld is offline
Thought I read where someone messed up their camshaft by not switching the gear. Can the gear be rotated and a new hole drilled? Someone who knows, chime in.
Old 03-21-2010, 06:42 PM
Mark Wilde's Avatar
Mark Wilde Mark Wilde is offline
I got lucky once and used mis-matched gears, with no nuclear explosion from the front of the motor. Ran great until my daughter totalled it.
I'd say, if the cam and dist gears appear to both be in good shape, take a chance. But that's me. Working in my garage, I'd chance it. Working for money, I'd change both.
90 Grand Wagoneer, 401/727/229, TFI upgrade, MC4350 4V, Edelbrock Performer cam, All-Aluminum Radiator, Razor Conversion, 4" Rusty's all-spring, 31x10.50 BFG TA/KO's...much planned, little time/money, thus she's a PipeDream!
Status: Up and running, but needs attention....
Old 03-21-2010, 06:52 PM
Tatsadasayago's Avatar
Tatsadasayago Tatsadasayago is offline
X2 what has already been said.
I'll add that there are several factors to consider here:
The few times that I actually got away with using a new dizzy gear with older cam gear is when I used the stock washer that goes under the distributor, kept the hold-down clamp TIGHT TIGHT and the cam gear was in good shape with NO sharpening of the teeth. This, along with good oiling will reduce the odds of losing both gears.
After having no less than 6 episodes of drive gear failure I REFUSE to take any chances. I bite the bullet and change the timing set (With the Bulltear stuff) and gears so I can drive more than 10 miles from home without the constant worry about WHEN, not IF, they are going to fail. That last round was with the GagOneer, on the interstate, nowhere to pull off and during the morning rush hour.
Murphy's Law says should you roll the dice, and the gears fail, it will likely be at the worst possible moment at the most in-opportune location.....
Good luck!
Jim
KY7DX/6
76 401 Wagoneer *The Gag-O-Neer*
77 360 W/T Cherokee Chief *Blair Jeep Project III* http://www.ifsja.org/forums/vb/showthread.php?t=113707
Sacramento, CA USA
Old 03-21-2010, 07:10 PM
GI-John's Avatar
GI-John GI-John is offline
I'm in the same boat. Just last week I ran into the same exact issue. (ebay Dizzy?) Unfortunately I went past the 30 day return policy and have to either throw it in and cross my fingers or suck it up and just do the TFI. (I was really hoping to clean up the engine bay, but oh well.
Good luck!
John
Just Emptying Every Pocket
Old 03-21-2010, 07:36 PM
SC/397's Avatar
SC/397 SC/397 is offline
I have gone through the dizzy problems as well. I have miss-matched OLD gears before many times and never had a problem. I have used a new (Crown) gear and had 25% wear in about 10 miles. So now, it is either old, original, used ones or the Bulltear set.
Regardless, be sure to coat the distributor gear with a liberal amount of petroleum jelly before you stab it in.
Old 03-21-2010, 07:46 PM
Casey's Avatar
Casey Casey is offline
Jeep Polygamist
I took the old gear off of my stock dist. and installed it on the CRT HEI. I had to mess around with the shims from the stock set up to get it to mesh properly. After a year there are no problems to report. Runs better than it ever did.
1994 YJ
1986 Comanche
'57 FC-150
Carolina Full Size Jeep Club
www.cfsjc.com
www.patriotguard.org
"Go forth and be a tool".
Old 03-21-2010, 08:52 PM
beloth's Avatar
beloth beloth is offline
Exclamation my HEI story
i got a reconditioned HEI jeep dizzy off a member here last spring...checked the gear out on it...looked fine...pulled my delco dizzy...gear on it looked ok....Shoot for two points...bong....delco dizzy hits the garbage can....installed the HEI dizzy exactly as it came...hooked up wires and power to it....one year later....still running great....
so like they have said...might be an issue or might not....i told my jeep quite plainly and in simple english the day we installed the dizzy...you freaking break this dizzy....i am selling your carcass to the junk yard....and like i said no problems 1 year later....
1966 wag "JENNY" w/1973 drivetrain
330K miles w/360 V8 2bbl (HEI installed ), flowmaster muffler
TH400 /Dana 20 transfer case D30 /D44 w/ 3.73's LT235/75/R15 AT tires. lift shackles in frt. 2 in lft; w/ TAD's Dozer bumpers! Cost $700 -now total cost=?
Old 03-21-2010, 10:08 PM
Mine is a Jeg's HEI dissy for AMC. they say the gear is not the hardened steal, more iron, so it should be o.k. We'll. I will grease it, stab it in, wire it up and go.
Now onto welding the exhaust manifolds since I removed the emissions stuff
1984 Grand Waggy
AMC 360
TF727
Soon to be NP208
Old 10-17-2010, 09:36 PM
jrlane's Avatar
jrlane jrlane is offline
stripped dizzy gear
Ok Fellows I stripped my Dizzy Gear Yesterday. I looked down in the hole and the cam looks fines. Do I need to get a Bulltear set or just replace the dizzy Gear> I do not want to tear it down. Also do I need to put a shim on the dizzy? Where I can I order Parts like Bulltear and shim? Maybe Part #s. Thanks
Old 10-17-2010, 10:05 PM
FSJ Guy FSJ Guy is offline
Holy DEAD THREAD REVIVAL!!
I'd replace the cam gear, too. If it chewed the distributor gear, it has worn the cam drive gear a little, too. Why chance it. I know, it's a PITA and a lot of work, but that's what I'd recommend. And you can throw on a new timing chain, too.
Ethan Brady
www.bigscaryjeep.com
Old 10-18-2010, 08:46 PM
Richo360 Richo360 is offline
Sorry to bear bad news but.......
I'd strip it down and replace the cam gear too.
I destroyed the cam gear after installing a HEI dizzy, and it filled the sump with little metal fillings..... not pretty. And not happy
A new matching dizzy and cam gear and an extra 10 hours or so on the tools fixed it (along with a couple of oil and filter changes and sump off and clean out etc).
There's been various discussions on the reasons, from not enough assembly lube, to mismatched gear bevel and cut, to different rockwell hardness of gears, and mis-allignment of machining of cheapo aftermarket timing covers.
Best bet is to get a matching set (ie Bulltear), and use lots of assembly lube. Also make sure the oil gallery on the front of the cam (and cam gear) is clear on reassembly. And the oil thrower on the crank is installed correctly too.
Old 10-19-2010, 09:01 AM
3nellieb's Avatar
3nellieb 3nellieb is offline
ok .looks like its been said but match your gears. built a new motor all new parts got matching gears from bulltear. put the one on the cam but figured sences they were all new and the problems id been hearing were about old gears and new dizzy, that i would be fine.boy was i wrong only lasted about 2 weeks before it chewwed up the gear on the cam and jumped timing.needless to say another $100 for gears and all that time taking the front end apart to change the gear(at least it was an amc with the timing gear in front).MAKE SURE THEY ARE MATCHED.this happened about 2 weeks ago.not fun.
Stupidity is often rewarded with pain.
86 waggy fresh 360 big bore tbi and all the works fresh727/208 4:27s front locked rear spooled 4'' bjs springs and 2'' body 37s irok(as of now) lots of cuttin.
Old 10-19-2010, 06:29 PM
3nellieb, its all a fun learning experience.
And why we lurve our old trucks so much
Quadratrac hard parts - the big picture Yogi Bear General FSJ Tech 118 03-05-2009 01:07 PM
Dizzy Gear bman General FSJ Tech 13 07-12-2007 01:26 PM
Dizzy Drive Gear BigBlueYJ General FSJ Tech 2 11-13-2006 06:07 PM
AMC/Jeep Manual Transmission Info James 007 General FSJ Tech 0 09-02-2002 07:40 AM
