Old 03-28-2008, 12:16 PM
Dirtball's Avatar
Dirtball Dirtball is offline
Loosening the steering column...
It was suggested to me a couple of years ago, when I had to get into my instruments, that the bolts holding the steering column not be loosened all the way. So, I didn't... just enough to drop the column down enough to pull the instrument cluster. The cluster would have been easier to get into if I had dropped the column down all the way; I need to get into it again to work on my heater and defrost cables and hoses, my headlight switch, and the intrument lights. I could pull the cluster out a lot farther and easier if the column was all the way out of the way.
IF it's a bad thing to drop the column all the way down... WHAT is the problem with it?
Paul
1979 Cherokee N/T
360/TH400/Qtrac/D44s/rear Lock-right
6 inch Hell Creek all spring lift
34x10.50 Super Swamper LTBs
http://i54.photobucket.com/albums/g1...t/100_1394.jpg
http://i54.photobucket.com/albums/g1...t/100_1390.jpg
http://i54.photobucket.com/albums/g1...100_1387-2.jpg
Old 03-28-2008, 12:26 PM
710 Burner's Avatar
You might need to disconnect the shifter linkage, but other than that, I don't see a problem.
Mark B. Jones
Old 03-28-2008, 12:27 PM
chrisnsarah's Avatar
You can go ahead and loosen them all the way and lower the column. You only need to lower it about 6 inches.
When retightening, the service manual is very specific about the torque, since the bracket has a breakaway feature and you can damage it or render it useless if you overtighten it.
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
Old 03-28-2008, 05:21 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Every dash cluster I've removed I've never dropped to column to do it... just more work to redo IMO.
Old 03-28-2008, 05:42 PM
AlsChopShop's Avatar
i've dropped the column before, no big deal. just DON'T lose the bolts. mine was a bit of a PITA because i also had the bracket (that goes back to the brake booster mount) loose and it wanted to move with the column. if you don't mess with anything but the column you shouldn't have a problem though.
Al
Old 03-28-2008, 05:59 PM
CustomWag's Avatar
CustomWag CustomWag is offline
Only pulled my cluster once to replace burned out bulbs, thought about dropping the column but was skeered. Tilt column was a definite plus, moved it all the way down and had plenty of room to work. I did put a cloth over the top of the column to keep from scratching it, as was suggested by someone here.
Rick
84 Custom GW
360/727/208/d44f/AMC20r/3:31
Manual windows/locks/seats
Old 03-28-2008, 08:16 PM
Dirtball's Avatar
When I pulled my cluster to replace the speedo cable I dropped the column as much as I thought I could and still keep the bolts attached and the cluster still wedged on the top of the column. Maybe I could have loosened them more; I don't know. I do remember wishing that I could just drop it down out of the way. I just know that I need it more out of the way to get to the headlight switch and the heater/defrost controls.
Paul
1979 Cherokee N/T
