Old 06-15-2019, 12:39 PM
Jenga77's Avatar
Jenga77 Jenga77 is offline
J20 Rim ID
Looking for some help identifying the rims on my truck. The four of them were on it when I bought it, but I'm looking to get a fifth for a spare tire and want it to match if possible. Also they're a perfect fit and I like the look so I'd like to match any new ones up.
I have J20 axles, so they're an 8 on 6.5" pattern with 9/16" studs, the centre hole is the correct size for the axles. They're a 16x7" rim, and solid, not a split rim. I'm not sure the offset / backspacing. They're steel with a chrome trim ring on the outside. Don't look like they ever would have had hubcaps or centre caps.
Anyone have an idea what these are off of so I can get started looking for another one? I have no idea if they're original or off a Chevy or something. I've searched around but can't find an exact match.
77 J10 - 360, T18, Dana 20, J20 Axles - Work in Progress!
Old 06-15-2019, 12:44 PM
there should be some stamping on the rear side of the wheel with some I.D. numbers you can use for help. need to clean off with a wire wheel to find them. they look like later model chevy rims.
Old 06-20-2019, 10:25 AM
Jenga77's Avatar
Okay, I'll see if I can find anything stamped into them, thanks.
Jeep J20 apache j20apacheh General FSJ Discussion 23 10-12-2016 09:06 PM
Towing a J20 on a Uhaul trailer jpcoutts General FSJ Discussion 9 08-08-2013 07:07 PM
1982 J/20 Honcho, We may have to build ;-) ! AMC-J/20 General FSJ Discussion 320 06-14-2011 04:39 PM
J20 axles in a J10 - Driveshaft ? HOOT General FSJ Tech 5 06-19-2008 08:36 PM
Factory J20 5/4 ton??? Elliott General FSJ Tech 17 09-20-2004 01:55 PM
