Old 06-13-2019, 02:54 PM
Vintage Jeeps Vintage Jeeps is offline
360 to T98 on j3000 DRW
Hi i am trying to bolt a 360 up to a T98 is there anyway of doing this thanks Mick
Old 06-13-2019, 03:14 PM
A Jeep T-98? What engine was in front of it originally?
AFAIK the only conversion product available today for the T-98 is for the inline 6 or the divorced T-98 used in the M715 military truck to a GM engine.
https://www.novak-adapt.com/catalog/...ion/gm/kit-c5/
https://www.advanceadapters.com/prod...w-input-shaft/
Even if you went for the Chevy V8, this adapter would not work without moving the transmission forward so the shifter is under the dash.
Old 06-13-2019, 04:51 PM
Thank you ... it still has its original early 232 ... i was thinking of buying a Bellhousing tfrom a Jeep T18 as it shares the same bolt pattern as the Jeep T98’ I know I would need the spacer also
Old 06-13-2019, 05:40 PM
airman's Avatar
airman airman is offline
You would also need a longer input shaft for the transmission
I am not sure if one is made.
Andrew
1969 J3000 Dauntless 350, T15, D20
1970 CJ6 Dauntless 350 , T350, D20
1951 CJ3A in the wings
Old 06-20-2019, 07:27 PM
The only V8 that came with a T-98 in these trucks is the AMC 327, which is completely incompatible with the 360. You'd need both the 327 and its T-98, which is different from the 232 T-98. We in the USA have a hard time finding parts for the 327, which would seem to rule out that option in Australia. You'd be better off to find a complete Jeep/Buick 350 or Jeep/AMC 360 and T-18 and transfer case and then swap in everything. These parts are not compatible with the T-98, whether paired with a 232 or 327.
Not a lot of alternatives - the T-98 is considered obsolete (replaced by the T-18), and has very little support even in the USA. The main problem you will have with a V8 is the odd way that Jeep adapted these trucks to V8 power. Jeep used a special transmission with a very long input shaft and bellhousing to move the V8 forward and clear the firewall. The engine compartment is shaped to fit an inline engine. Nothing but your 232 or smaller AMC early 6s will fit the existing bellhousing and transmission. Conceivably one could adapt a different Ford or Chevrolet or AMC inline 6 engine using the existing Novak or Advanced adapter, but only the Chevy six would bolt up without some modification.
If you use the existing transmission and a V8 engine, you must move the transmission forward and the shifter will be under the dash. You could heat the shifter stalk and bend it to clear the dash. This also requires changing eh length of the driveshafts and other changes. And you'll still need the Advance or Novak adapter kit, which is meant for a GM V8, not an AMC 360.
These Kaiser era trucks were assembled from commodity components that were spec'd to fit the existing platform. Not much unity in the drivetrain before AMC took over.
amc 360 vs dodge 360 Carleysjeep General FSJ Tech 37 05-13-2009 10:56 PM
AMC 360 to CJ 5 Swap CJ Runner Off-Road FSJ Tech 4 10-31-2008 10:52 AM
AMC 360 cam gear issues Cartman General FSJ Discussion 1 10-20-2008 07:00 PM
will a 2barrel carb off 360 fit 304? Robber80 General FSJ Tech 7 05-03-2006 06:39 AM
360 better than 258?? Scruffy Engine 6 07-24-2000 08:04 AM
