Old 12-04-2018, 07:41 PM
djmac's Avatar
djmac djmac is offline
How to troubleshoot a GM OBD1 ignition
I know this is the fuel injection forum but I have a GM OBD1 system controlling fuel and spark in my 82 J10 with a Ford 460. I had trouble with my IAC and found that the stock wiring pinout was wrong for my new Holley Tbody. I reversed the wiring and corrected that issue but ended up with no spark. I have an MSD 6A ignition box and jumped the test terminal and got a very strong spark out of the coil. With the key on I have no voltage at the coil + terminal but I understand that is normal with just the key on. My issue is I don't know the sequence of operation between the ECM and Ignition Control module and coil. I disconnected my ecm to troubleshoot the IAC so I could have disturbed a connection there. I replaced the Ignition Control Module no luck. So does anyone know with the key on what voltage I should be reading at the wiring harness connection to the ICM? My module has a 2 pin and 4 pin connection on one side and a two pin (input?) connection on the other. I believe if I knew what 8 terminal should read voltage wise with the key on I could track the issue down. This system came out of a 91 Camaro if that helps and I a standard billet dizzy with the computer controlling spark. This link has a ICM similar to mine. http://www.fieros.de/en/v6help/code42.html
Thanks in advance for any ideas
82 J10 SOA 6" SPRINGS D60-D70 W/DETROIT LOCKERS 38x15.5 TSL'S on 12" M/T CLASSICS 460 V-8 C-6 CUSTOM EFIS EFI AND HYDROBOOST
Old 12-05-2018, 07:24 AM
Maybe it's early and I need more coffee but the diagram you posted shows you the module power pin.
1994 Caprice wagon
Old 12-05-2018, 05:34 PM
djmac's Avatar
As helpful as the pinout appears it does not tell me what to anticipate and test for with the key on. Given that I am not familiar enough with the sequence of operation I need to know where to expect the switched 12v current to show up when you turn the key on. Usually, it would be at the + terminal of the coil? Or in this case does the ignition key send 12v to the MSD? What comes from the ECM when the key is on? There are 6 pins on one side of the module as you can see in the picture. When the key is on what Voltage should these terminals be outputting? There are 2 pins on the other side of the module what voltage should they be outputting when the key is on or cranking? Maybe I am making this harder than it needs to be but I it appears to me that's the info I need to troubleshoot this one.
Old 12-05-2018, 06:47 PM
Module should get power key on/crank "+" on diagram you linked.
MSD would need same on ignition wire.
ECM would also need same on ignition wire.
There is a voltage check sheet for ecm probably find it on thirdgen or gearhead-efi.
Also full wiring diagrams.
1994 Caprice wagon
Old 12-06-2018, 07:13 AM
djmac's Avatar
Thumbs up
Exactly what I needed thanks alot.
Old 12-15-2018, 11:55 AM
djmac's Avatar
Thanks alot for the info. The guys at thirdgen were great and had the details I needed. My beast is starting and running great. It turns out I damaged the ICM while rewiring the IAC. I had suspected that and replaced the ICM but I did not actually mount it but rather just plugged it into the wiring harness when I tested the new one. I thought the wiring harness would ground it but it does not. Once I ran a test jumper to ground it she started right up and then I bolted it down and all was good.
Old 12-15-2018, 12:15 PM
It should be grounded via the harness, if you have to add a jumper something isn't correct.
Very unusual for an ecm to actually be bad, 95% time it's a wiring issue and frequently poor grounds.
This is a resource for a TBI wiring diagram I modified for folks.
http://www.ifsja.org/forums/vb/showthread.php?t=169223
1994 Caprice wagon
Old 12-15-2018, 12:25 PM
djmac's Avatar
Thank, I will check it my harness out
Old 12-19-2018, 02:10 AM
ICM must be mounted on a heat sink and bolted to ground. Preferably, directly to the engine, not the firewall or inner fender.
The module grounds thru the mounting screws.
There is a low ref signal gnd wire but that does not provide the ground for the high power transistor used to fire the coil.
It's all been covered on binderplanet.
Bill USN-1
Hamilton Fuel Injection
Old 12-19-2018, 07:45 AM
djmac's Avatar
Thanks Bill!
Old 12-19-2018, 08:39 AM
Apologies...my brain saw/read ECM. Bill is correct, ICM must be mounted properly.
1994 Caprice wagon
ignition failure - 88 GW fulsizjeep General FSJ Tech 11 10-25-2009 10:02 PM
Ignition Switch/Cylinder trspeegle General FSJ Tech 2 07-02-2009 11:23 PM
Pertronix Ignition? 88sunroof General FSJ Tech 14 06-18-2009 08:12 PM
What is the Juice box? Ignition Coil? Tempest General FSJ Tech 11 07-17-2006 10:47 AM
7 miles per gallon ?!?!?!?! jode General FSJ Tech 33 03-13-2004 02:32 AM
