Old 03-18-2019, 06:26 AM
Originally Posted by rockosocko
Good morning.
Is this motor going in with an auto trans?
And what gear ratio size tire?
Also, what type/size of carb
I'm kinda trying to decide on either the Comp 268 and a MTA-1 (AMC-360 TH400)
Intake gaskets need attention, so I'd be half way there anyway..
Thanks
E
Motor is installed in front of an auto trans (stock TH400 with a mild shift kit and stock converter)
Stock 3.55's (i think... Might be 3.73, whatever came stock in a 79 Cherokee Chief with a 360).
Tires are 285/75-16 (about 32.5" tall)
Running a GM DIY Throttle body injection with computer controlled timing.
Runs pretty well, idle is pretty smooth. I have about 5 miles on the motor so far and am still tuning the EFI. My build thread (link in my signature has more details).
Old 03-19-2019, 02:23 PM
rockosocko's Avatar
rockosocko rockosocko is offline
Hhhmmm. Makes me want to give that TBI another shot.
Got a few parts off of a rental truck with a big block. But the Throttle body has some huge solenoids/sensors on it that doesn't look 'normal'
So, with that 268 she's idling smooth and no vacuum problems with the IAC when cold?
Thanks for chatting with me to.
E
Old 03-19-2019, 08:05 PM
jeepman1's Avatar
jeepman1 jeepman1 is offline
Mine works..
I had my heads surfaced, ran the 268 cam and just ordered original size pushrods, runs good so far w/ stock rockers.
: 98 9er
'83 Honcho j10
'12 Liberty Ltd.. wifes
'19 Chaparral H2o Dlx sport 21
Will stock valve covers clear roller rockers? Strode General FSJ Tech 4 09-25-2012 10:10 AM
BRAKE LINES IN STOCK NOW cttandy General FSJ Tech 6 05-31-2008 11:36 AM
Name the weak link - 35s on stock axles? RamJetFSJ Off-Road FSJ Tech 34 07-17-2006 03:00 AM
will 31's fit under a stock ride? Madduck General FSJ Tech 12 06-20-2006 07:48 AM
